383mazda
I need some catching up to do!
What was going to be a tranny swap (paid $350 for it - Shep built trans that had been sitting in a corner of a buddies garage), balance shaft delete and timing belt ($500 maybe??) turned into a $2000 bill... the further I dug the more I had to replace
Some off the new stuff
(Not shown is also a new crank timing belt gear, belts, top timing cover, exhaust mani studs and lots more I've forgotten already, lol)
Decided to play it safe and replace entire clutch (ACT 2600 was rediculous on stock power, and 8lb flywheel didn't make sense either). Went with street light flywheel and 2100 pressure plate and disk:
Check out exhaust housing!! Lol. Wastegate port looked the same way...
Replaced that with 7cm unit, ported to match 2g O2 housing and Evo3 manifold. Looks good
