4G63 Cyclone Non-Turbo - Unexplained warning lights in the speedometer
Ali_6306
Active member
Lahore, Pakistan
Guys here is another caution light. Its been in many speedometers I have seen, but never seen one that is working. I attempted to reverse engineer it, but there is no wire in this vehicle's harness to operate it. Just wondering what it may be for:
misterfixit
Midlands, UK
Thats low headlight washer fluid, not coolant. In all the EU cars i've had it's been that.
I don't have a uk owners manual scanned here though so I can't post the manual blurb.
Has it got head light washers?
Rich
Ali_6306
Active member
Lahore, Pakistan
Neither my car nor the donor had headlight washer. Which explains why this light was not operative.
About the CAT temp sensor: The resistance I got here was not working as it produced erratic resistance everytime I checked. So I visited the electronics market and without much effort got hold of a variable resistance (0 to 100 ohms). It works perfect once set to produce 15 ohms resistance. Before I connect it to ECM, can you confirm whether all I need to do is to connect the wires (red & white) to two interfaces of the variable resistance? Is there any thing else I need to pay attention to?
I believe if the light goes out, it means success. /ubbthreads/images/graemlins/smile.gif
Ali
misterfixit
Midlands, UK
yup. Just connect the two wires to the load.
As it's a variable resistance you could do a sweep and let us know whats the minimum it goes out at /ubbthreads/images/graemlins/smile.gif
Rich
Ali_6306
Active member
Lahore, Pakistan
Hi Rich,
Issue fixed. I connected the wires to the resistance and light goes out. Thankyou for the help mate! (Y)
The variable resistance I have ranges from 1.3 to 108 ohms. I checked all through the range, but the CAT temp light stays off until it is disconnected.
Thank you again for the guidance!
Regards,
Ali
