4 wheel steering
Vman911
Douglas county, Ga
what are some of your guys opnion's on the 4 wheel steering? I have no problems with mine so far. I just got a 4 bolt LSD this weekend and was thinking of keeping my 4WS and swaping the guts on the pumpkin's. Keep it or get rid of it? does it help that much? Thanks Vinman
Quoting Vman911:
Personally id keep it, its getting even rarer to see a gvr4 with full intact AWS, i replaced my entire unit to keep mine..
just my .02
Jesse
Lonewolf64
Birmingham, Alabama
Remove it. It will be a pain in the ass later on when it breaks (and it will break).
CarRacer
Shakopee, MN
Keep it.
I'm contemplating the same thing. If mine works I'm keeping it. It's one of the things that makes our cars unique.
On the other hand, if it's broken I'm taking it out. Parts are scare or not available and it will be a huge pita to fix.
jepherz
KC, Missouri
I pulled it on one of my cars even though it worked cause I built it for performance. Another I plan to just drive on the street, so I'm going to keep it as long as it works and doesn't leak.
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
keep it until it breaks or doesn't function correctly and then decide.
pachood_1953
eau claire, wi
Quoting jepherz:
So how do you know if it "works"? I cant really tell what mines doing back there. Our's dont move under 30ish MPH does it?
belize1334
Bozeman, MT
Find a windy road. Then take a medium corner and accelerate from 20mph to 30mph. Around 25 mph you'll feel the tail step in which will cause your steering radius to increase and the point of rotation to move forward. You'll have to turn in more to compensate and keep in on the road. When that happens it's doing what it's supposed to. At freeway speeds it makes merging and abrupt lateral movements easier. It's only problem when you spend time transitioning at the change over speed because it upsets the motion of the car. So if it's a DD and you don't care, then keep it. If you're doing autox or something like that then you'll want to rip it out.
