4 bolt install/ 4ws removal.. Its not that messy..
Rear pump - 5lbs
Rear rack - 15lbs (actually I can't remember if this was 10 or 15)
I'd estimate all the other lines and fluid that are removed to be 10lbs at the MOST. So we're looking at a maximum of 30lbs drop for a 4ws removal.
And of course if you put a 4 bolt back in there, they weigh more.
3 bolt axles are 10lbs a piece.
3 bolt LSD rear is 46lbs
Anyone have 4 bolt weights?
Mark
when you remove the 4ws rack, does this affect the wheel alignment at all, or does it just come out and then thats it, your sweet to drive???
quote:Originally posted by Bigfoot:
Whithout the rack it's just like the TELs. Mitsubishi calls that passive RWS. I thought they called it "Active Toe".
RayH
NJ
4 bolt axle 12lbs each
4 bolt LSD rear 47.5lbs
Wow.. resurrection, but I was searching and saw this question.. Once the rack comes off you're ready to go!
