238/2000
bcallahan92
Westfield ma
DSS Aluminum Driveshaft for GVR4 (MISH3-HD)​
Yes, no extra work needed, bolted right up. They send you spacer with the drive shaft that bolts up perfectly. I did get a carrier bearing from jxb performance as well. With this driveshaft you only need one carrier bearing. Thank you I appreciate it !
nazagalant1993
buenos aires , argentina
I like the location of the oil radiator. I will undoubtedly borrow many of the solutions you used on your car. I will soon upload the story of my car and its process. It is very difficult to build a car in Argentina there are only 5 GVR4 units
SpyderGSX
Member
Plymouth, MA
Awesome build! Looking really clean and very well done. I’m going to pick up #1788 tomorrow! I’m also in Massachusetts. Plymouth to be exact. Got a buddy with a 1g DSM in town too. Gotta get this thing running so we can all meet up sometime! Hopefully by the summer!? Good luck!
Turbo99
Haverhill, MA
Providing I stop being a lazy POS and get 1803 back together before summer I'm down for a MA get together
bcallahan92
Westfield ma
off to a buddys shop to clean up some wiring and a few other things. Wrapped the hood its not latched and the rear bumper sides arent fully bolted in. Helps it stay secured while getting towed. Still a few little things to do like the dog legs and those side fenders. But while im not able to work on it, im getting at least something done to it. 2 1/2 years so far on this build. Finally seeing the finish line shortly !
bcallahan92
Westfield ma
Im finally home to work on the galant. Had to connect some of the harness under the dash and do a few other things. Went to fire it up and with the help of a buddy we got it started for only a couple seconds. But ! It sounded amazing. Feels like weight has been lifted off my shoulders. Digging around a bit we always came back to this relay. Sure enough popped the cover off, what do we find. So funny, this actually worked for sh*t 10 years ? Not once have I opened this to take a look. If you did this, I hope you found a good laugh tonight. Your work lasted many years.
