1st engine build.
spooling92vr4
long island, NY
I wouldnt run that topline head gasket... All the others in the kit should be fine, I would shell out a few extra bucks for a dealer multiplayer or regular head gasket. also when I redid my motor I found an oil pump that was made by aisin I believe they make our oem joints.
yeti
san diego california
yeah im looking for the ones from aisin but cant find they right make/year
i think i might just go with the one from slowboy racing
rdomeck
Indianapolis, In.
If you have any concern about your oil pump and do not know what to look for, I would suggest taking it to your machine shop and let them take a look at it for you. It would also depend on if your rebuilding because there was a bunch of trash that ruined your bearings or your just rebuild to freshen things up. Like one of the previous post said it all depends on what it looks like. I used to rebuild Porsche engines and some of this oil pumps could push $3000. You can do a lot of checking, cleaning and repairing for $3000!
Have someone who rebuilds engines for a living look at it and see if it's worn. If it looks ok to them have them do some measuring and see if the shafts are worn or the bores for the shafts are worn. A good machine shop will charge about $15 to check it out and then you will know for sure. Water pump should be replaced no matter what for $30!
yeti
both oil pump and water pump already ordered
thanks though im more of pulling my hair out trying to figure out my other thread /ubbthreads/images/graemlins/mad.gif.
rag3
Active member
Princeton, NJ
If it not a bad ground or blown fuse it could also be the alternator. if it has a bad connect it could also drain the battery.
