Did some more work towards making this thing happen... Gaskets came in so I was able to close the engine back up. I was set on adding balance shafts back in, but after thinking about it some more... I said naw and kept them deleted. I can deal with a little bit of vibrating since it'll be on stock mounts with an insert or two. I packed the pump full of grease, and replaced the front case gasket that had been leaking a little previously. I also went ahead and drilled out the oil passage ways on this case while I was there, and radiused it a bit
The previous accessory setup on this engine in the 1G was a stock filter housing/sandwich cooler, side exit exhaust, and rear mounted Saturn alternator. It had a FFOH from a not turbo also at one point, which didn't really matter for the side exit, it was just nice having a cooler. This time Ill be keeping AC, and going back to alternator up front.
It all went pretty good there, I was happy to see the AC compressor clearing the cyclone with no issues, a DSM compressor will not I know that!
Unfortunately I ran into a little roadblock here... Which I kinda foresaw, just been a while since Ive had a more "conventional" setup to deal with... I'm thinking here I will go back to a FFOFH just to get the car going, then I'll do a sandwich cooler once its needed.
