NateCrisman
Quoting Dbossman:
Nice. Congrats! /ubbthreads/images/graemlins/applause.gif
So what were you running the 14b in, and what was your best pass?
The 14B efforts were back in 2004 in a 1g AWD DSM. (a yellow 90).
It went
11.9 @ 111 in "stock appearing" legal trim for the Shootout race. Stock sidemount ic, stock ic pipes, 14b, 1g maf. no nitrous
11.4 @ 118 with a wet nitrous kit. 3080lb total weight.
At the time, we weren't really super serious about setting any record or getting the best ET possible with a 14b as the only restriction. We were putting a car together either for a budget race where you can only spend $2004, or setting the car up to race in the stock appearing class at the shootout. Both situations obviously have much more restriction on performance than "14b only". The GRM race the car had to autox and carshow. The stock appearing class bar's fmic, external wastegates, nitrous, intake manifolds, and you have to use a 1g maf. We were also running on a junkyard motor that pushed coolant from day 1. The motor was so wasted, after the 11.4s the HG was so beat the car wouldn't even run to drive on trailer. There was no budget for machine work to mill the head flat so we just took a head that was literally laying in the grass with rusty valvetrain...swapped in clean rockers and bolted it down with a stock HG. The sort of thing you do when you only need the engine to run for about 20 passes and if it blows up...who cares, we were just having fun.
Point being that even though the 11.4 was the 14b record for a while, it was a happy accident. We at no time had anything close to a car setup with intent to go as fast as possible with the stock turbo. And at that time, noone besides me and Leon Reitman had even cared to try and run fast on a 14b just for bragging rights.
Then Joe Bucci built a crazy 1g fwd laser and went absolutely bonkers with weight loss. He got his 14b car down to like 2100lb with driver, and smoked me: 10.86 on motor/10.61 with nitrous. That was a car built for a serious purpose.
So knowing what I know 5 years later, Im pretty confident I can beat that FWD car. I'm going to have to make up for the weight difference with better power and better 60'. His best runs were low 1.6 short times, I can go mid 1.4s. I don't believe Joe really leaned hard on his nitrous setup, I'd be really pushing the spray and tailoring the setup around nitrous.
This was the car: (pic from GRM magazine who puts on the $2000 challenge race)
you can tell from the pic it wasn't a serious effort: street wheels, ground effects, mirrors, steel hood. hahaha streetcar stuff. Getting the 14b and 16g records these days requires a full out effort on weight loss. I think a 1gawd will need to be less than 2300lb and go 1.400 to beat Bucci's 10.86 14b/no nitrous run.
It went
