Galant VR-4 Forums » Galant VR-4 » Newbies » Awd clutch in nt fwd trans
Galant VR-4 org Post #: 1236168 posted 03/29/17 10:30 AM     Remind Me!  Send Private Message   Edit Post
I'm putting together a nt eclipse I just bought and would like to throw in a lightweight flywheel I have for an awd. I've seen people say it is the same size ring gear and it will work. Then I've seen other people say it doesn't fit in the bell housing because it's too tall. Has anyone done this successfully?
I just measured the two bell housings and couldn't find any where the nt was narrower than an awd trans. The ring gears are the same distance from the block and the distance between the teeth and end of the pressure plate is the same. I don't see why it won't work.
7 1G DSM's now a GGSX build.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1236169 posted 03/29/17 10:36 AM     Remind Me!  Send Private Message   Edit Post
The AWD flywheel is smaller in diameter than the FWD, thus the ring gear is too. The FWD will not fit in an AWD trans bell housing (my experience), so you may be ok the way you are planning. You will likely need the AWD starter mount plate to locate the starter properly due to the diameter difference. Again, my personal experience when I put an FWD engine into AWD application.
Edited by iceman69510 (03/29/17 10:37 AM)
Posts: 10498 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1236170 posted 03/29/17 10:38 AM     Remind Me!  Send Private Message   Edit Post
Did they use a different starter on the NT for any reason? As long as the starter teeth are the same number, it sounds like you measured everything.
Don't have a solid answer to your question, but from the measuring you already did, it sounds safe to try.
1992 Nile black w/sunroof
14xK miles. 2nd owner since 1998
Posts: 5754 | From: Lafayette, IN | Member Since: 08/06/02 | IP: (128.210.106.177) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1236175 posted 03/29/17 11:43 AM     Remind Me!  Send Private Message   Edit Post
All starters are the same for this purpose. It is the spacer plate that clocks it. Comparing only standard trans starters, automatic have a different plunge depth and are incompatible in this regard.
I did some sleuthing, to prove my point.
Enjoy .... all starter.
C53A 1 of the ~1500
Posts: 1535 | From: THE Ottawa | Member Since: 03/05/05 | IP: (173.206.108.86) | Report this post to a Moderator
Galant VR-4 org Post #: 1236181 posted 03/29/17 02:04 PM     Remind Me!  Send Private Message   Edit Post
I know the fwd turbo flywheel is bigger. I also know the nonturbo flywheel is not stepped.
So with a awd starter plate (if they are different), there shouldn't be any reason the clutch shouldn't work.
828/1000
Galant VR-4 org Post #: 1236183 posted 03/29/17 02:51 PM     Remind Me!  Send Private Message   Edit Post
The plates are different. I have them both.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Galant VR-4 org Post #: 1236186 posted 03/29/17 05:59 PM     Remind Me!  Send Private Message   Edit Post
Your talking about the fwd nonturbo plate right?
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:24c7:6) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1236196 posted 03/30/17 07:16 AM     Remind Me!  Send Private Message   Edit Post
Thinking back on it, not 100% sure, but I believe turbo. The engine was a turbo and the plate was on it. I didn't know about the flywheel difference, but found out when trying to put the trans on that it wouldn't fit over the FWD flywheel. It was at that point I changed the flywheel and engine starter plate to AWD stuff with no futher issues.
Galant VR-4 org Post #: 1236198 posted 03/30/17 07:50 AM     Remind Me!  Send Private Message   Edit Post
Yes the turbo fwd flywheel is definitely larger.
I'm hoping for info on the nonturbo trans. I'm pretty sure I'm just going to have to assemble everything to test it before I buy new parts. Was just hoping I could be saved the trouble with positive confirmation. Everything is covered with gobs and gobs of oil.
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1236199 posted 03/30/17 08:08 AM     Remind Me!  Send Private Message   Edit Post
Yea, Turbo FWD transmission is 110 teeth on the ring gear. AWD Turbo is 106 teeth
Thom
Posts: 712 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1236203 posted 03/30/17 11:05 AM     Remind Me!  Send Private Message   Edit Post
Established... asking about nonturbo... never mind.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:5449:c) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1236204 posted 03/30/17 12:01 PM     Remind Me!  Send Private Message   Edit Post
What trans model number do you have?
828/1000
Galant VR-4 org Post #: 1236205 posted 03/30/17 12:15 PM     Remind Me!  Send Private Message   Edit Post
According to CAPS:
Starter plate for D22 NT M/T and D27 M/T is the same: MD030141
Thus flywheel diameter is likely the same. Do you have the NT flywheel to compare diameter? You suggest so in your first post.
Are you worried about the clutch height with the step being too deep into the NT trans?
Sorry if we have run all around the issue, but I for one was not thinking NT only when initially answering. I have never owned an NT 1g.
1025/2000
Galant VR-4 org Post #: 1236206 posted 03/30/17 12:54 PM     Remind Me!  Send Private Message   Edit Post
You just gotta make sure you match the PP to the flywheel. If you plan on using a turbo flywheel, you will need the turbo PP, and visa versa.
Thom
Galant VR-4 org Post #: 1236208 posted 03/30/17 01:29 PM     Remind Me!  Send Private Message   Edit Post
The same. That's what I figured. I don't know why I didn't look that up. I just figured I would have found someone who actually did it. Everything seems in order. I'm going to go ahead and have that flywheel surfaced and give it a go. Thanks you guys.
Edit: a guy from the tuner site says he's tried it and it doesn't work. That the clutch assembly is too big. I'm going to have to assemble and test fit it when I get my awd trans off my bench.
Edited by tektic (03/31/17 10:18 AM)
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1236232 posted 04/01/17 09:47 AM     Remind Me!  Send Private Message   Edit Post
A KM210 and F5M33 trans will have no issues with any matched set Mitsubishi type flywheel/pressure plate/clutch. All the Colt C53A turbo cars came with a KM210, and I have successfully run the stock FWD 215mm flat flywheel/clutch/pressure plate and the FWD DSM 225mm stepped flywheel and matching ACT clutch in both bell housings.
KM210 FWD transmission (Colt C53A)
C53A stock turbo 215mm flat flywheel
C53A stock turbo 215mm clutch and pressure plate
MB1-HDSS ACT 2100 clutch and pressure plate
Fidanza FWD DSM aluminum flywheel with removable friction insert 8.2 lbs # 161651
and
MD995656 FWD 1991-92 F5M33-2-SPZV (FWD DSM)
All setups used the same stock C53A KM210 starter plate for obvious reasons.
Now, I say this to prove a point but also to illustrate that you could be using the KM206 or similar 5 speed transmission. Those tranmissions were mated to 1.6L NA motors, and likely others, but I don't know if they have larger or smaller bell housings, to be able to accommodate larger flywheel setups like the FWD DSM flywheel.
C53A 1 of the ~1500
Edited by FlyingEagle (04/01/17 09:53 AM)
Posts: 1535 | From: THE Ottawa | Member Since: 03/05/05 | IP: (68.171.77.46) | Report this post to a Moderator
Galant VR-4 org Post #: 1236259 posted 04/02/17 09:31 PM     Remind Me!  Send Private Message   Edit Post
Kf5m222vpzv is the trans from the nt eclipse. I don't imagine it's smaller.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2604:2000:1480:8) | Report this post to a Moderator
Galant VR-4 org Post #: 1236362 posted 04/05/17 10:55 AM     Remind Me!  Send Private Message   Edit Post
So close yet:
When bolted together the clutch hits this hump where the little white triangle is in the picture.
Going to open my gst trans to inspect that and will add an awd 5th gear while I'm in there. Hope the gearing doesn't feel too slow in nt form.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (67.81.192.148) | Report this post to a Moderator
1 registered and 27 anonymous users are browsing this forum.
Generated in 0.135 seconds in which 0.098 seconds were spent on a total of 14 queries. Turbo powered.
