Galant VR-4 Forums » Galant VR-4 » Newbies » Quarter Glass seals??
somekidsgarge
Newbie
574/1000
Galant VR-4 org Post #: 1234655 posted 01/05/17 08:05 PM     Remind Me!  Send Private Message   Edit Post
The rear quarter glass on both sides are leaking, is there any seals or gasket I can buy still??? Or what can you use to seal up the windows???
Posts: 4 | From: PG, UT | Member Since: 08/29/16 | IP: (75.169.230.185) | Report this post to a Moderator
Galant VR-4 org Post #: 1234656 posted 01/05/17 08:20 PM     Remind Me!  Send Private Message   Edit Post
They are sealed with butyl, like what is used for the taillights. You can buy rope butyl at body shop supply stores to replace it. I had one that did not leak water, but leaked air. I pulled it out and resealed it with new butyl.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10532 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1234657 posted 01/05/17 08:21 PM     Remind Me!  Send Private Message   Edit Post
You use a non hardening windscreen sealer. It's like a black goopy goo that gets everywhere.
Posts: 2078 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (180.181.213.100) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1234658 posted 01/05/17 08:31 PM     Remind Me!  Send Private Message   Edit Post
here. click i actually need to go get some.
138/2000
Edited by transparentdsm (01/05/17 08:31 PM)
Posts: 3444 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
somekidsgarge
Newbie
574/1000
Galant VR-4 org Post #: 1234737 posted 01/09/17 07:55 PM     Remind Me!  Send Private Message   Edit Post
Cool I'll go look for some!! One more question, how does the glass come off? Does the window just peal off or is there a stud at the top and bottom with a nut holding them on?
Posts: 4 | From: PG, UT | Member Since: 08/29/16 | IP: (75.169.238.69) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1234738 posted 01/09/17 08:05 PM     Remind Me!  Send Private Message   Edit Post
Pull the interior plastic and you will find 4 screws.
138/2000
Edited by transparentdsm (01/09/17 08:06 PM)
somekidsgarge
Newbie
574/1000
Galant VR-4 org Post #: 1234739 posted 01/09/17 08:26 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help!!! Hopefully this weekend I can get them sealed up!
pot
182/1000
Galant VR-4 org Post #: 1234741 posted 01/09/17 08:46 PM     Remind Me!  Send Private Message   Edit Post
Quoting transparentdsm:
Once you remove the interior plastic trim you will find four 10mm nuts. Furthermore, the only Sealant you should use is the OEM Sealant. It is part no 8609 Super Fast Urethane from 3M. You should be able to source this product from any Bodyshop retailer.
I have attached an image from the FSM to aid you. Using the factory application and method will prevent you from performing this procedure twice.
182/1000
Edited by spatchana (01/09/17 08:49 PM)
Posts: 1420 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (66.87.132.230) | Report this post to a Moderator
somekidsgarge
Newbie
574/1000
Galant VR-4 org Post #: 1234744 posted 01/09/17 10:33 PM     Remind Me!  Send Private Message   Edit Post
Thanks for all the help!
Posts: 4 | From: PG, UT | Member Since: 08/29/16 | IP: (97.126.251.74) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1234752 posted 01/10/17 08:51 AM     Remind Me!  Send Private Message   Edit Post
Quoting spatchana:
thank you pot, i did not realize it was a certain kind of sealant. on the screw part, thats just my bad. thanks for this, like i said im gonna be doing it here soon.
138/2000
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1234757 posted 01/10/17 02:56 PM     Remind Me!  Send Private Message   Edit Post
Also run a garden hose over it afterwards to make sure it is totally sealed, and don't over tighten the nuts or you will have glass all over the place.
Posts: 341 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1237357 posted 05/21/17 03:25 AM     Remind Me!  Send Private Message   Edit Post
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8824 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
TheRedBaran3
Newbie
Galant VR-4 org Post #: 1238431 posted 07/09/17 07:38 AM     Remind Me!  Send Private Message   Edit Post
I have rear window glass and seal of that doesn't work out for you
Posts: 6 | From: Buffalo, NY | Member Since: 09/04/15 | IP: (108.17.27.77) | Report this post to a Moderator
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.29 seconds in which 0.268 seconds were spent on a total of 14 queries. Turbo powered.
