Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » thomcasey's rescue of #1025 build
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1191365 posted 10/14/14 09:08 AM     Remind Me!  Send Private Message   Edit Post
Ressurecting #1025/2000. Here are the plans,
Here as she sits in a sad but rust free state:
Here are the plans (many parts coming off my swapped 91 Colt:
-On-hand/performed-
E316g
PTE 680'd
ECMLink v3 Full
Aeromotive AFPR
Wally 255
Tial Q BOV
Tial 38mm WG, vented
SBR ex manifold with WG mount
4-bolt lds rearend
5-lug swap
working AC (hopefully still good)
TRE Stage 2 transmission
TRE rebuilt xfer case
Keeping the balance shafts
Stock motor
Stock exhaust for winter
16x8 VOXX et20 5-lug wheels
GlowShift Oil Pressure, Coolant temp and Boost gauges (white face, from Colt)
Pioneer DEH-X8500 BH head unit
Kicker 10.2 amp (fronts)
MB Quart FX 1.600 mono amp (Sub)
Kicker Comp 10" sub in sealed box
NRG ST-009R-RS Steering wheel
NRG Quick release hub
Full replacement interior
-Need/to be performed-
Innovative LC-2 WB
AWS delete
new front struts w/1"drop
new front axles
re-install entire dash/vents
re-install entire interior
rebuild driveshaft
Door speakers
Dash speakers
rear deck speakers
-Summer-
Paint
2.5" exhaust
Tint
Posts: 805 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (50.58.165.200) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1191366 posted 10/14/14 09:28 AM     Remind Me!  Send Private Message   Edit Post
Make sure you check the front lower control arms, they tend to rust out at the rear bushing and get loads of play. Also make sure to check over all the brakes and suspension(sure you knew that).
Maintenance is very important as these babies are getting old.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
866/1000
Galant VR-4 org Post #: 1191370 posted 10/14/14 10:00 AM     Remind Me!  Send Private Message   Edit Post
Yea, no rust there. Front calipers are in my house, rears are OK so far on the back
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
866/1000
Galant VR-4 org Post #: 1192932 posted 11/01/14 08:47 PM     Remind Me!  Send Private Message   Edit Post
got standed with no car for a while today, so took advantage of the sunny yet 38 degree weather and cleaned out the galant and placed the interior in it to get it out of the house.
Posts: 805 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2602:30a:c094:91) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1192933 posted 11/01/14 08:55 PM     Remind Me!  Send Private Message   Edit Post
Welcome to the .org!
-Craig
1501 Build Thread
Edited by LIV4PSI (11/01/14 08:56 PM)
Posts: 1761 | From: O-H-I-O | Member Since: 11/24/11 | IP: (98.31.3.95) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1193034 posted 11/03/14 06:30 AM     Remind Me!  Send Private Message   Edit Post
Decided to change up the motor build for this. Instead of the freshly ringed and gasketed stocker, I will run:
fresh tanked and machined block, .020 over
Wiseco .020 pistons
Eagle Rods (balanced with pistons)
fresh crank
BSE (I am a huge fan of Balance shafts, but what the heck)
Ported and polished head
272 cams
ARP head studs
Will still be running the stock VR4 FMIC and exhaust for the winter, then the summer will see the new FMIC and exhaust
It is over-kill for my build expectations of sticking with the e316g forever and such, but could not pass up the trade. (Trading for my 93 Summit AWD Auto wagon)
Thom
bluzvr4
Galant VR-4 org Post #: 1193336 posted 11/06/14 01:31 PM     Remind Me!  Send Private Message   Edit Post
So when i found out my engine was bad the first guy I called said he just got rid of his only extra.... We have the same friends
73 Opel gt (race car)
51/2000 (being built now)
94 vr4 (the pretty one)
Posts: 57 | From: san jose IL | Member Since: 02/21/11 | IP: (174.238.229.167) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1194206 posted 11/17/14 02:05 PM     Remind Me!  Send Private Message   Edit Post
Well, I managed to eeek out a Rebuilt title from the Indiana BMV!!! So the build can go forth!! I found hail-damage on the roof and trunk, I think that is why it was totaled in the past so a rebuilt title is the best I could do.
The motor build has changed a bit as I now have the parts and now know what they are exactly:
.020 bored and machined stock block
.020 9.0:1 Wiseco pistons
Tool Steel wrist pins
Eagle H-Beam rods
un-cut polished stock crank
ARP L19 headstuds
-----All the above picked up on a trade for a 93 Auto AWD Summit wagon, good trade------
polished/ported head
272/272 cams
new 3g lifters
Had new bearings installed in the front 5-lug hubs so I will finish the 5-lug swap
Thom
866/1000
Galant VR-4 org Post #: 1195376 posted 12/01/14 07:36 AM     Remind Me!  Send Private Message   Edit Post
Put in a little work on Saturday since it was nice and warm in the 40's. Installed my 5-lug front knuckles with the fresh bearings. Went ahead and installed new ball joints, stab-links and tie rod ends too. Front struts are toast, rust infested (only rust on the car!!). Unfortunately I discovered some play in the passenger inner tie rod. Guess I will pull the rack and replace those too.
Thom
138/2000
Galant VR-4 org Post #: 1195378 posted 12/01/14 07:53 AM     Remind Me!  Send Private Message   Edit Post
unless the rack is leaking or you really want to drop it, you do not need to remove the rack to change the inner tie rods.
138/2000
Posts: 3507 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (24.180.38.35) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1195385 posted 12/01/14 10:48 AM     Remind Me!  Send Private Message   Edit Post
I thought a special tool was required to do it with the rack in the car.
Quoting transparentdsm:
Thom
Galant VR-4 org Post #: 1195389 posted 12/01/14 11:12 AM     Remind Me!  Send Private Message   Edit Post
You can probably do it with a pipe wrench. You may also have to bend back the retainer washer tabs too, but that doesn't need anything special.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10617 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1195390 posted 12/01/14 11:14 AM     Remind Me!  Send Private Message   Edit Post
23mm open ended wrench i think. or 21 or 25. i just did it a year and a half ago with the car on a jack. just remove any crossmember or braces in the way. took me no longer then an hour or so to do.
138/2000
Wookalar
ignore this pathetic weasel he's just not worth the time
3/1000
Galant VR-4 org Post #: 1195395 posted 12/01/14 12:46 PM     Remind Me!  Send Private Message   Edit Post
Wow, who are these fools who fray out the wiring system like that, and zip tie a heavy compressor to a aluminum line? They should be restricted to public transit at the least.
Enjoy the build.
</font><blockquote><font class="small">Quoting 89Patches:</font><hr />
Brett gstwithpsi is the nut rider!
<hr /></blockquote><font class="pos
Posts: 458 | From: Arizona USSA | Member Since: 11/27/13 | IP: (24.251.4.211) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1195398 posted 12/01/14 01:15 PM     Remind Me!  Send Private Message   Edit Post
I absolutely agree!!. It looks like they were going to either re-loom or wire tuck and stopped. Fortunately the line is still solid and still holds pressure. I have since straightened that line (ever so carefully) and set the compressor on the cradle.
Quoting Wookalar:
Enjoy the build.
866/1000
Galant VR-4 org Post #: 1196443 posted 12/14/14 06:28 PM     Remind Me!  Send Private Message   Edit Post
Saturday was in the Mid 40's, nice and warm for driveway work!!! Went to work on getting the dash installed:
Pulled the dash to install the vent system. Found this on the heater core when I removed the semi installed dash:
The heater core did not work properly, was unable to redirect air since the knob would not move. I found the core was filled with AT LEAST a bunch of acorns, maybe the body of the snake was there too. So, I installed a new core.
Install complete:
Only issue I found were following wires, no idea where they should go:
These are from under the steering wheel:
These coming from the center console area:
This is where the ECU goes:
And this wire. No place for it to go to in the harness:
Anyone know what I can use to mount the speedo cable? there is no clip to hold it in place in the gauge cluster mount?
Also found these mounts in the trunk. Are any of these for the gvr4?
Thom
Edited by thomcasey (12/14/14 06:52 PM)
Galant VR-4 org Post #: 1196485 posted 12/15/14 07:53 AM     Remind Me!  Send Private Message   Edit Post
Auto dsm?
7 1G DSM's now a GGSX build.
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.22.58) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1196515 posted 12/15/14 02:19 PM     Remind Me!  Send Private Message   Edit Post
Figures. My luck they would not be the correct ones. I was completely surprised to find a complete dash minus only the two small dash panel/switches and the little panel that finishes off the lower left dash so I was hopeful for these mounts, but no more.
Thom
Wolfpuss
1392/2000
Galant VR-4 org Post #: 1196523 posted 12/15/14 03:22 PM     Remind Me!  Send Private Message   Edit Post
Damm, I would have called it quits when I saw the snake skin (I hate snakes)
Keep up the good work OP!
Posts: 156 | From: St Louis | Member Since: 07/08/14 | IP: (68.188.70.110) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1196524 posted 12/15/14 03:25 PM     Remind Me!  Send Private Message   Edit Post
In the image (six from the bottom) is the glove box light.
182/1000
Posts: 1456 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (66.87.133.97) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1196586 posted 12/16/14 06:22 AM     Remind Me!  Send Private Message   Edit Post
Thanks!! One down, two to go.
Quoting Pot:
Thom
866/1000
Galant VR-4 org Post #: 1196587 posted 12/16/14 06:25 AM     Remind Me!  Send Private Message   Edit Post
LOL, I grew up in Arizona, played with many a snake, but I was really cautious. That is why I replaced the heater core, don't need any snake issues like Chapell had in Gone in 60 Seconds.
Quoting Wolfpuss:
Thom
182/1000
Galant VR-4 org Post #: 1196645 posted 12/16/14 02:28 PM     Remind Me!  Send Private Message   Edit Post
Also, in the following images (from the top):
- 3rd Image is more than likely a portion of a turbo timer harness *You can go ahead and remove it and reconnect your factory harness. You'll see what I mean when you remove the panel below the steering wheel.
- 5th Image that circuit is taped exposed (not connected) to the factory engine management portion i.e. ECU connector loom
- 6th Image Courtesy of Muskrat:
Also, you can Consult Chapter 13 (Fuel) of the Factory Service Manual Volume 1 for additional reference.
182/1000
Posts: 1456 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (65.191.158.26) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1197029 posted 12/21/14 09:37 AM     Remind Me!  Send Private Message   Edit Post
Went out to install a new inner tie rod because the jam nut was seized to the rod and it had some play. Once I removed it I also found it a little bent.
Thom
138/2000
Galant VR-4 org Post #: 1197030 posted 12/21/14 09:53 AM     Remind Me!  Send Private Message   Edit Post
damn that thing is toasted.
138/2000
Pages: 1 | 2 | 3 | 4
0 registered and 25 anonymous users are browsing this forum.
Generated in 0.285 seconds in which 0.22 seconds were spent on a total of 14 queries. Turbo powered.
