Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » GSX_TC's Galant VR4 Build Thread #550/2000 (Samara)
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072015 posted 06/16/12 09:18 PM     Remind Me!  Send Private Message   Edit Post
Pauter Rods, Ross Racing Pistons, ARP everything polished crank, Clevite 77 bearings
Cometic Head gasket, 3 angle valve job, Ferrea stainless valves, double springs, titanium retainers and 3g lifters, FP2 cams, HKS cam gears, and power enterprise kevlar timing belt.
Spearco 2-216 Front mount
New power steering rack
Redline fluids for the Trans, transfer case and rear diff
ACT Streetlite flywheel and ARP flywheel bolts
Fluidampr with ARP crank Bolt
All new gaskets, bolts, washers, Orings etc etc
new OEM Mitsu Clutch master and Slave and throw out bearing with braided clutch line
new OEM Mitsu Alternator and Starter
new OEM Mitsu belts, Walboro 255 fuel pump, OEM 0/2 sensor, thermostat, fuel filter, and spark plugs.
DSMlink version 3, speed density parts, and HKS BOV
K&N filters
STM external oil cooler kit
new OEM lower cover, zaklee upper clear cover, and FP2 cams with my powdercoated Valve cover
Edited by GSX_TC (12/27/12 07:19 PM)
Posts: 3701 | From: Houston, Texas | Member Since: 04/07/11 | IP: (50.8.62.199) | Report this post to a Moderator
pot
182/1000
Galant VR-4 org Post #: 1072025 posted 06/17/12 12:05 AM     Remind Me!  Send Private Message   Edit Post
No better way to spend the G.I. Bill/and or Student loans ---your FP Cams are gonna hate you resting on the bare concrete. Love the pic of the belts, thermostat, radiator cap, etc.
Why are you running a '90 ECU Mike?
182/1000
Edited by Pot (06/17/12 12:12 AM)
Posts: 1420 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (12.94.50.134) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072028 posted 06/17/12 12:46 AM     Remind Me!  Send Private Message   Edit Post
Don't worry I gently placed them there. Thanks man, I'm running a 90 because it had a 90 in it when I first got it, so all I did was switch pins 6 and 14 if I remember correctly because they were never switched, then sent the 90 to get chipped and socketed.
JZX90 Toyota Mark II Tourer V Twin Turbskie "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara" 550<
(208.54.83.138) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1072029 posted 06/17/12 01:32 AM     Remind Me!  Send Private Message   Edit Post
I thought the same thing when I saw the cams on rough concrete.
-Mark
1051
Posts: 11875 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.185.43.218) | Report this post to a Moderator
jmelocik
1564/2000
438/2000
Galant VR-4 org Post #: 1072030 posted 06/17/12 01:33 AM     Remind Me!  Send Private Message   Edit Post
You driving this thing to the shootout? Would be good to see several GVR4s there. I'll be driving mine if the military will allow me the time off.
Josh
A veteran is someone who, at one point in his life, wrote a blank check made payable to 'The U S of A 'for an amount of 'up to and including my life.' That is Honor, and there are way too many people in this country who no longer understand it.
Posts: 126 | From: Cameron, NC | Member Since: 07/24/11 | IP: (84.247.46.214) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072062 posted 06/17/12 11:52 AM     Remind Me!  Send Private Message   Edit Post
Yep that's the plan, I'll be driving all the way there and back. As long as you put in for your leave a month or two in advance it should get approved unless your gonna deploy soon.
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 1072069 posted 06/17/12 02:04 PM     Remind Me!  Send Private Message   Edit Post
Is Mike at FIST doing the motor build?
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3846 | From: Cypress, TX | Member Since: 08/07/02 | IP: (76.30.185.53) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072079 posted 06/17/12 04:24 PM     Remind Me!  Send Private Message   Edit Post
Mike built the motor but someone else will be putting it in. Mike is in the process of relocating his shop, so he doesnt have time right now.
(208.54.83.210) | Report this post to a Moderator
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1072082 posted 06/17/12 05:05 PM     Remind Me!  Send Private Message   Edit Post
Not gonna lie that is a nice build. Glad to see quality parts going into it.
Michael
The rebuild of 1101
Posts: 4081 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (24.251.35.165) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072084 posted 06/17/12 05:13 PM     Remind Me!  Send Private Message   Edit Post
Thanks buddy, I'll be sure to keep updating on this as I go along. I can't wait to See how nice the intercooler piping comes out. I just ordered an FP intake so I can't wait till that comes in.
faqinshiet
Member +
Galant VR-4 org Post #: 1072086 posted 06/17/12 05:54 PM     Remind Me!  Send Private Message   Edit Post
Nice! What type of numbers are you shooting for?
90 GGSX-VR4 clone
Posts: 468 | From: Arlington, Va | Member Since: 12/06/11 | IP: (198.228.216.17) | Report this post to a Moderator
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1072157 posted 06/18/12 03:09 AM     Remind Me!  Send Private Message   Edit Post
Looks like things are going good for you down in TX. Lots of OEM parts...nice. I'm especially stoked on the OEM alternator. Good call. Remember my alternator swapfest? After i went through a couple more parts store remans, Zak let me use an old OEM alt he had laying around and i've been driving the car a couple days a week since, 14-14.5 volts all the time.
Posts: 1924 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (68.5.153.146) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1072162 posted 06/18/12 04:01 AM     Remind Me!  Send Private Message   Edit Post
I don't think the reman'd Mitsu alternators and starters are as good as the originals, after hearing of others' luck with them having as many issues as some of the regular parts stores varieties. I'm pretty sure they don't come from Japan. If they were that good, I'd purchase those over the Bosch units I run. That said, all the other new OE parts are awesome.
-Mark
1051
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072186 posted 06/18/12 08:54 AM     Remind Me!  Send Private Message   Edit Post
Quoting ApexHunter:
Yeah I remember that, you were going through them fast, I'm glad you got that fixed. Zak is great people
(208.54.83.141) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1072199 posted 06/18/12 10:36 AM     Remind Me!  Send Private Message   Edit Post
That is an awful nice pile of parts. The shootout is getting close Mike, get your game face on!
Posts: 1755 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.205.175) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072201 posted 06/18/12 10:44 AM     Remind Me!  Send Private Message   Edit Post
oh Hell yeah! =)
Okayplayer
Member +
1968/2000
Galant VR-4 org Post #: 1072205 posted 06/18/12 10:58 AM     Remind Me!  Send Private Message   Edit Post
So what turbo are you using with this setup? What are your power goals? So many nice things there, you should share
My car eats turbos
1991 Galant VR4 (1968/2000 NB)
2006 Galant SE
1986 Chevy C10
Posts: 255 | From: Denver, CO | Member Since: 01/14/10 | IP: (75.71.188.11) | Report this post to a Moderator
Galant VR-4 org Post #: 1072207 posted 06/18/12 11:06 AM     Remind Me!  Send Private Message   Edit Post
Mike,
Kudos to you for sticking with this, that car is really going to be nice when it is finished ... speaking of which, I didn't see an exhaust in that pile of parts
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (118.141.68.113) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1072216 posted 06/18/12 12:40 PM     Remind Me!  Send Private Message   Edit Post
Quoting Okayplayer:
Currently I'm still on my EVO 3, orginally I wanted to get the Hta68 right before the shootout but I'm realizing I'm running out of money fast and I still need to budget for the trip. Powe goal is a healthy 500 to the wheels with a/c and daily driver status still just like it is right now. =)
Quoting cheekychimp:
Mike,
Lol Actually I was Thinking of taking it all off and just going the whole trip with open downpipe, but I don't know. I don't wanna attract alot of cops attention during the big trip. Plus I like how quiet that muffler is that's on it and still 3 inches. I've driven my 1g around with open exhast like that for like 7 or 8 years so I can def handle the loudness, but like I said I just don't wanna attract the unwanted attention, but who knows, I might just do it anyways
Edited by GSX_TC (06/18/12 12:49 PM)
(208.54.83.139) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1073908 posted 07/01/12 12:13 AM     Remind Me!  Send Private Message   Edit Post
got another piece to add to the build.
FP 4inch intake non recirculated, with massive K&N filter and a miracle reducer coupler that allows that huge intake to fit onto my evo III big 16g =)
Galant VR-4 org Post #: 1073919 posted 07/01/12 02:03 AM     Remind Me!  Send Private Message   Edit Post
Mike,
Before you put that Fluidampr on make sure you bolt it to your OEM pulley and check the timing marks line up!
Posts: 7298 | From: Hong Kong, New Territories | Member Since: 04/19/04 | IP: (118.141.68.187) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1073942 posted 07/01/12 10:55 AM     Remind Me!  Send Private Message   Edit Post
Will do, thanks for the heads up.
(208.54.83.194) | Report this post to a Moderator
Galant VR-4 org Post #: 1073952 posted 07/01/12 11:37 AM     Remind Me!  Send Private Message   Edit Post
Yeah it may not be an issue if that's a recently manufactured one as I think that they have rectified the issue, but Brian had a dud one and so did I. If it is a bad one and you don't catch it before you put it on, you can't tell easily just by looking and you end up setting the timing over and over, only to find the car runs like crap!
Banthony
555/1000
Galant VR-4 org Post #: 1073995 posted 07/01/12 07:57 PM     Remind Me!  Send Private Message   Edit Post
What's the point of the springs on the dump tube?
97 CBR900RR
2012 Hyundai Veloster
Posts: 3513 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (98.237.211.124) | Report this post to a Moderator
JNR
5 star (English Professor) member math and reading skills need work
20/1000
Galant VR-4 org Post #: 1074008 posted 07/01/12 09:49 PM     Remind Me!  Send Private Message   Edit Post
Didn't even notice that...inquiring minds wants to know.
Posts: 9740 | From: ca | Member Since: 04/23/04 | IP: (71.103.93.126) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20>>
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.272 seconds in which 0.226 seconds were spent on a total of 14 queries. Turbo powered.
