WTB: Toyota 3 wire pigtail
G
zompton
Maybe one of you who frequents salvage yards can find 2 of these for me. I'm looking for the female version of this. From a mid nineties toyota. Corner, blinker or running lamp. Will pay top $.
G
zompton
I think 4runner, rwd pickups or 4wd pickups. But could also be on any nineties toyota.
bradrs
Alta Loma, CA
Quoting G:
What is considered top $ for this crowd?
I found the connectors new, for $5 each. click
They are also used on a 3000GT on a 3 pin connector somewhere around the fuel rail, if you want to search for those in a junkyard.
G
zompton
Can't see the pics. I'll take them for $5.00 each.
G
zompton
As of right now I still need them.
bradrs
Alta Loma, CA
Those are a slightly closer match than the one I linked to. The one I posted was a version used on Mitsubishis that should be plug in compatible. Several companies make compatible versions of that style of connector. But the one on the Toyota looks closer to the one you posted.
The other connectors on that light are interesting. They are using a sealed connector, but did not put the seals on the wiring.
89Mirageman
Stantonsburg, NC
Have you considered just grabbing any male and female 3 wire connectors from the JY, cutting that one off and just soldering on a new one? That way they are made for each other and nobody will ever know the difference.
jepherz
KC, Missouri
Quoting bradrs:
Look at the brand. It's a depo!
