What turbos are direct replacement for 14b?
paul j
Lone Tree, CO
I can not find this info in my searches. What turbo will be a direct bolt in replacement for stock 14b?
G
zompton
How are you defining "direct bolt in"?
paul j
Lone Tree, CO
Direct to me means the stock mounting, exhaust, vacuum, water, oil etc connections for the 14b attach to the new turbo with no alteration. I suppose a minor adaption would be ok.
curtis
Clarksville TN
Maybe another 14b? /ubbthreads/images/graemlins/grin.gif
gvr4ever
central Indiana
Keep in mind, if you go to a 16g, you will probably want a upgraded exhaust manifold too. Check to see if the turbo you get has a 6 or 7cm outlet. You can also port too.
