jepherz
For starters, I got a brand new 3g MAF from a member here a long while back, probably 5-6 years ago. To be honest, besides burning a chip with the 3g MAF tables in it, I didn't do much tuning OR driving of the car for years. The last few years I've tracked it and had a conservative tune. It was hard not to notice, though, that there was some weird behavior on partial throttle around 2-3000 RPM. AFR's would first jump up to around 15-16 AFR and the car felt SLOW. Then, as soon as AFRs rose, they dropped off again and the car took off like a bat out of hell.
I've now installed an Evo ECU with the intent on being able to log and tune easier. To my surprise, with a few Evo maps with only injector corrections (PTE 780s) the car behaves the EXACT same. I tried to take some logs although I'm no tuner so I'm not totally sure what to look for. I logged MAF hz vs. AFR vs. RPM and it seems like the only similarities are partial throttle acceleration. Somewhere between 150--200 hz I am having issues. But the strange thing is, if I am just cruising and not under load, the AFRs seem fine at that same frequency from the MAF.
In order to narrow it down a bit, I locked the ECU into open loop and set the fuel tables to 11:1 AFR to see what would happen. Here is a log segment to show what I'm talking about:
Code:
I haven't messed with the MAF tuning at all because frankly, I'm not sure I should have to. Yes, my ECU rom is set up for an Evo MAF but they flow so closely that it shouldn't be a problem. I had the actual 3g tables in my ROM on my 1g ECU and had the same problem anyways.
Anyone have any ideas? I'm tearing my hair out trying to think of what the problem is. I will buy a new 3g or Evo MAF if there is something wrong with mine, I just don't want to throw parts at the car without having a good feeling about what is wrong. Could my intake piping have anything to do with it? My BOV is recirc'd fairly close to the MAF coupler, could that matter?
Help!
Code:
Code:
TPS RPM AirFlow ECULoad W02
20 2187 150 58.75 11.68566
20.3 2187 150 59.375 11.86143
20.3 2218 150 59.375 11.74425
20 2250 150 59.375 11.68566
20.3 2250 150 59.375 11.74425
20.3 2250 150 58.75 11.74425
20.3 2250 156.25 59.375 11.80284
20.3 2281 156.25 59.375 11.80284
20.3 2312 156.25 59.375 11.86143
20.3 2281 156.25 59.375 11.86143
20.3 2312 156.25 59.375 11.97861
20.3 2312 156.25 58.75 11.97861
20.3 2343 156.25 60 11.97861
20.3 2343 162.5 60 12.0372
20.3 2375 162.5 58.75 12.0372
20.3 2375 162.5 59.375 12.15438
20.3 2406 162.5 60 12.27156
20.3 2437 162.5 59.375 12.15438
20.3 2437 162.5 59.375 12.21297
20.3 2437 168.75 59.375 12.21297
20.3 2437 168.75 59.375 12.27156
20.3 2468 168.75 60 12.21297
20.3 2468 168.75 59.375 12.21297
20.3 2500 168.75 59.375 12.21297
20.3 2468 168.75 59.375 12.38874
20.3 2531 168.75 59.375 12.44733
20.7 2500 175 60.625 12.38874
20.7 2562 175 59.375 12.27156
20.7 2531 168.75 59.375 12.38874
20.3 2562 175 59.375 12.6231
20.3 2562 175 60 12.6231
20.7 2593 175 59.375 12.6231
20.7 2562 175 59.375 12.79887
20.7 2593 175 59.375 12.79887
20.7 2593 181.25 60 13.209
20.7 2625 181.25 60 13.32618
20.7 2625 181.25 60 13.38477
21.1 2625 181.25 60 13.44336
20.7 2687 181.25 60 13.32618
21.1 2656 181.25 58.75 13.32618
21.1 2687 187.5 60.625 13.44336
21.1 2687 187.5 60 13.67772
21.1 2718 187.5 60 13.61913
21.1 2718 193.75 60.625 13.67772
21.1 2718 187.5 59.375 13.61913
21.1 2750 187.5 60 13.209
21.1 2781 187.5 59.375 13.09182
21.1 2750 187.5 59.375 12.91605
21.1 2781 187.5 58.75 12.79887
21.1 2812 187.5 58.75 12.68169
21.1 2812 193.75 58.75 12.6231
21.1 2812 193.75 59.375 12.50592
21.1 2843 193.75 59.375 12.21297
Help!
