What are potential problems from installing ARP's upside?
turbophein
mass
i pulled the VC after doing a compression test. test results were 0-70-0-90 psi I found a set of ARP's installed upside down!!! the allen head side is in the block, so in turn they are all at different heights in the head because they couldn't screw them in properly. so i'm hoping that maybe the headgasket blew within the 5 miles he said he drove it. then he said it idled rough the next morning and then died out and wouldn't start. he said he and his buddy rebuilt the whole engine. i don't know how i feel about this, nothing else i can visually see is correctly done.
Looking for opinions on the headgasket, before i rip into it. lol
EHmotorsports
Beaverton
Lets just hope none of the threads pulled out of the block due to not being screwed in all of the way. I would remove the head and have it checked out for warpage and test to make sure the valves are sealing properly. after that i would clean out and inspect the threads in the block. also verify the head studs are not binding in the head due to the bigger diameter studs. you will know if you can't get the head off with the studs in the block. (my guess is they installed the studs after they dropped the head on) also replace the headgasket any time you remove the head.
transparentdsm
Cherry Hill, NJ
^ agreed, replace head gasket and have head checked and even resurfaced if you can. who knows you might not be in to bad of shape.
turbophein
mass
thanks for your input. i'm hoping the bottom end is good as i do not want to do a motor swap mid winter. its only getting colder here with no garage.
i mainly want to know if you guys think the compression l lost was from the headgasket blowing out versus piston problems. thats what it is in my mind. he did send me a video of it running or 30 sec lol.
