Weight reduction numbers...
Where can i find more info on this carbon fiber hood? Any kind of ETA? Thanks again!
Polish
I have been trying to get my cars weight down since I have had it. I recently acquired a digital scale and weighed everything I had. There are a few things I trashed or never had that I would like to know what they weigh. If someone could help me out there that would be great. I have removed an easy 250lbs so far but I don't know an exact # because of the missing weights. I will update this post with new findings as I get them. I also will include weights of various stock parts. I still have tons more stuff to remove. I have full intentions to have this car under 3K with me in it.
Sunroof 40lbs
2 AC Heat Under dash boxes (far right ones) 13.2lbs The Center Heater core I didnt weight but it was another few lbs, not super heavy.
AC compressor 17.2lbs
B- Shaft 2.4Lbs
Glove Box 8.5lbs
Radio 6Lbs
Tool Kit 1.5lbs
Jack 5Lbs
6 Speakers 8Lbs
Trunk Panels 10Lbs
Sunroof Brackets 4.5Lbs
Antenna 3Lbs
Fog Lights 3Lbs
Rear Belts 5.5Lbs
Washer Fluid Tank 1Lb
Charcoal Canister 3Lbs
Cruise 6.5Lbs
Alarm Horn .5Lb
AC Tension Pulley 2.5Lbs
Bumper Center Section, Various Brackets and Panels, 8Lbs
Visors and Oh sh*t handles 3.5Lbs
Under Dash Drivers 3Lbs
Trunk Sound deadening 4lbs
Rear toe hooks 6lbs
Rear bumper support brackets and bolts 2lbs
rear bumper support 40lbs
*some of the* abs wire loom 2lbs
Volk wheels -2lbs each 8lbs
213.3 is the total of just the stuff I could weigh.
Front Bumper Support(most of it) Est 38lbs
AC condenser and metal lines 4lbs Est
Spare tire l7lbs Est
AC Evaporator 1lb Est
Lots of little things 3lbs
ABS unit and ecu 35lbs
311.3 lbs so far. Assuming the estimates are pretty accurate.
------ Misc items weight ------
Rear Bumper foam support 8lbs
Stock 1G O2 housing 5Lbs
14B 16.5Lbs
6Cm housing 10Lbs
1G Ex Mani 11.5Lbs
Cyclone Intake 18.0 Lbs
Stock IC GVR4 3Lbs
Added this from a post I made a while back in this thread.
