Trunk Cable not opening trunk
It just started one day. I can see that the red plastic bit that goes to the rear latch is broken, so I held it in place and had a helper pull. The cable still doesn't pull quite enough to open the trunk.
Seems like a simple but annoying problem.
Ideas?
Thanks
SouthCaliVR4
North county San Diego
On mine the cable got stretched & needs to be replaced. check that it's still mounted to the clips on the hinge & the retention clips that run under the back seat.
Quoting SouthCaliVR4:
I guess I'll check all that stuff out...thanks.
Quoting omertaitalia:
so you dont know why its not working still?, sounds like a future junk yard trip to me.
No idea, no Galants of these years appear in junk yards here even the big ones.
turbofonz
Granby, MA
On my car I know the lever is just weak and pulling bends the lever rather then pulling the cable.
curtis
Clarksville TN
Take the cable off in the back and crimp on a steel or aluminum cable clamp piece available at any hardware store or just put a zip tie on it to take up the slack. Fixed without having to tread the cable from under the carpet etc.
