Transmisson
Hondakiller
Deltona Florida
How much power can a factory trans. hold? Im going to have the tranny rebuilt but dont know if I should rebuild it to stock or just beef it up.
Nartanian
Richfield, MN
My friend made 466whp on stock tranny. What it boils down to is how much you abuse it through launches and slamming it through gears.
Hondakiller
Deltona Florida
The engine that Im building is able to hold 800hp. But Im going for 500hp. but I want to build a tranny that will last so stock is not good enough cuz i drive my cars hard. so Ill just biuld a bad ass tranny.
CutlassJim
Manchester, NH
Then why f***ing ask?
Gears in a DSM style trans shear at 500ft/lb beatings with traction but you can toast syncros with 90 hp and a crap hydraulic system or bad shifting skillzzzzz. Got any more dumb questions to not put in the newb section? I got a sh*t load of wise ass answers in my magical bottomless bag of wise ass answers. /ubbthreads/images/graemlins/grin.gif
Quoting Hondakiller:
If you want something not factory, then you'll need a dogbox from somebody like Magnus. All other transmissions use some combo of factory parts/gears/bearings/synchros/etc.
BPU925
katy, tx
or you could convert it to auto..... /ubbthreads/images/graemlins/dunno.gif
or you can just run stock til it blows...
enough said.
4thStroke
Vancouver, WA
Quoting BPU925:
And endure all the growing pains associated with that? It's not as simple as just throwing in an auto. It's not even as simple as finding all the drivetrain and hard parts to make the swap possible. It goes well beyond that to get a properly performing automatic setup, and to say otherwise is ignorant.
I've been daily driving my stock "refreshened" tranny at 440whp for close to two years now. It boils down to self control. I've launched the car maybe 5 times and do not slam gears.
I learned the hard way the first time and do not want to repeat what I did in the past. I made several 2nd through 4th gear rips while daily driving at 530whp and ended up shredding 3rd in just a few thousand miles. If you beat on any DSM tranny on a daily basis, it will break. Whether it be from small gears being fatigued, or user error with a dogbox, it's not difficult to do.
4thStroke
Vancouver, WA
I figured I'd update this a little.
I'm back at daily driving the car at about 550whp. The car blows the tires off in 1st even with ECMLink keeping boost to 20psi, it spins 2nd once the turbo respools (30+psi from 2nd to 5th)), and pulls hard in 3rd, spinning any time the tires hit some sort of imperfection in the road. I've made a few pulls on the stock tranny and I expect it to hold for some time as long as I don't do back to back pulls and heat up the gears repeatedly. The tranny is not set up for the quickest shifting despite having a twin disc for clutch duty, so i doubt I'll explode a gear from slamming.
