tranny removal help
Tommyd
Fishkill, NY
Hey guys, I've looked around and couldn't find an answer so. The engine and Tranny are out of 610 and I can not get the the transmission to come off the engine. All the bolts holding it in are out and the transmission is about 3/4 of an inch off the block but something is still holding it back. Is there something with the clutch fork I'm not doing? I don't want to man handle it off and break something.
DynastyLCD
Harwinton, CT
there's 3 bolt on the front of it, and one bolt on the back of it going from the engine into the transmission, you could be missing that.
also, the transfer case must be removed as well.
DynastyLCD
Harwinton, CT
does it still have the front dust shield bolted to it by chance? if not, shake and wiggle it until it comes free
Tommyd
Fishkill, NY
Well apparently all I had to do is man handle it more. Sorry for wasting your time, just wanted to make sure I didn't break anything
DynastyLCD
Harwinton, CT
i've seen it before where people go to take apart an all stock one and forget the transmission dust shield near the front roll stop, or the one underneath by the transfer case. i've even done that myself before lol
Lancer99
Somewhere over the rainbow
Sometimes I've had to wrestle the trans off the engine so it could be a pain in the butt. The shaft also has to come all they way out to fully be apart.
H05TYL
Wgtn, NZ
Not on the vr4, but I once pulled a gearbox out of a rotary converted Mitsi L200 pick-up that had twisted the input shaft enough that I had to unbolt the pressure plate from the flywheel (through the inspection hole) to get the box off!
Tommyd
Fishkill, NY
Well on the Subies you have to actually remove the clutch fork in order to remove the tranny by threading a bolt into the "pivot" pin that goes through it. That is a pull type instead of push, and my first time dropping that transmission it took 2 hours of trying to wrestle it off before I broke my throw out bearing. I wanted to be a little cautious and not break anything on this car as it was my first time pulling everything apart. Now I've learned.
Boostin_AWD
Active member
Utah
The evo is a tricky one as well. Its a pull style with a wave ring you have to unlock through the inspection cover. Most dsm trannys I've delt with are usually pretty good. Some just require a little coaxing. Glad to head all went well.
