Tranny code question
that axle cup is just a bit longer. it needs it so the c-clip on the splines can engage in the diff, check your axle and see if itll just pop out. but, mine isnt a clutch type. what came factory? ive heard viscous and torsen types came in them
also, i need to add to this as well. i now know the information given to me about my tranny, which ends in WQEK, was wrong, and it is also a close ratio, 3.909 final drive gear box. according to shep, the shift forks are stronger, as well as some other minor differences. this box can never be converted to a dual syncro first, due to a wider first gear(physical width inside the tranny)? this box also has a viscous front lsd. norco found info on the tranny as well, it is from the latest production run of evo/rs galants.
I know i'm grave digging on my first post but I have the answer. I also have a W5M312VPXZ, and after searching the archives here in GVR4.org , I found a Russian website with tranny codes and corresponding chassis codes: Russian Site Translated. N43W is the chassis code that matched W5M312VPXZ, which is a JDM Mitsubishi Chariot GT, basically a sporty, turbocharged, 227hp Expo.
Here's the only english specs I could find on the car: http://english.auto.vl.ru/catalog/16383/
Still, no gear ratios.
I've gotta JDM-Switchable Transmission too. Any Idea on the CAPS specifications?
Stealling this from someone else, then from another more so for JDM stuff...
W5M33 - Firstly, M=manual. Secondly, W5*33 seems to be any (F/4WD based) 4G63 or 4G91 engine gearbox.
The last 4 letters tell you all the important things:
1st Part: Final Drive Ratio
N - 4.929 (VR4)
W - 5.358 (VR4 Evo and up)
U - 5.433 (Evo 3)
2nd Part:
G -
P - Evo 2/3 Gearbox (Double syncros on 2nd, 3rd and 4th gears, 2.750 and 1.684 ratios on first and second
Q - VR4, VR4 Evo, Evo 1 gearbox
R -
3rd Part: Front LSD?
B -
F - Front LSD (RS - Mechanical LSD)
G - Non LSD (GSR)
N -
V -
W - Front LSD (GSR - Viscous LSD)
X -
Y - Non LSD (RS)
4th Part: Vehicle
D - 90+ Mirage Cyborg
E - 92+ Cxxx Lancer
F - 92+ Galant (AKO Style)
K - 88+ E3xx Galant
W5M33-2-NQBK E39A VR4 *Facelift*
W5M33-2-WQFK VR4 Evo (LSD - Mechanical?)
W5M33-2-WQNK VR4 Evo
W5M33-2-WQFE Evo 1 RS (LSD)
W5M33-2-WPYE Evo 2 RS (Non LSD)
W5M33-2-UPFE Evo 3 RS (LSD)
Adding this for archive purpose. I pulled this from another thread on this board. It was a link to a NZ board.
GearBox Code / Vehicle / Front LSD /Ratio
W5M33-2-NGRE Lancer gsr RS (1992, 1800cc) ?
W5M33-2-NNZT Eclipse AWD 5spd mfg 3/94 ?
W5M33-2-NPXV 91-94 Eclipse AWD 5spd mfg 6/90-2/94 ?
W5M33-2-NPZT 95-96 Eclipse AWD 5spd mfg 3/94-6/96 ?
W5M33-2-NQBE Libero/Lancer Gsr, non lsd version No 3.545
W5M33-2-NQBK 1991-92 to 4/92 VR4/ZR4 Galant ?
W5M33-2-NQBM 1992 Galant to 5/92 ?
W5M33-2-NRBE 92-95 Lancer GSR, lightweight synco's 2nd & 3rd No 3.545
W5M33-2-NRWE 92-95 Lancer GSR, stronger box, dbl syncro 2nd Yes 3.545
W5M33-2-NRXD 1990 Cyborg No 3.545
W5M33-2-UPFE Evo3 RS with front LSD Yes 3.909
W5M33-2-UPGE Evo3 GSR non LSD No 3.909
W5M33-2-UPWE Evo3 GSR with front LSD Yes 3.909
W5M33-2-UPYE Evo3 RS non LSD No 3.909
W5M33-2-WPFE Evo2 RS with front LSD Yes 3.909
W5M33-2-WPGE Evo2 GSR non LSD No 3.909
W5M33-2-WPVF Galant VR4 E84A ?
W5M33-2-WPWE Evo2 GSR with front LSD Yes 3.909
W5M33-2-WPYE Evo2 RS non LSD No 3.909
W5M33-2-WQFE Evo1 RS with front LSD Yes 3.909
W5M33-2-WQFK Galant VR4 evo ? ?
W5M33-2-WQGE Evo1 GSR non LSD No 3.909
W5M33-2-WQNK VR4 Evo, close ratio box ? No 3.909
W5M33-2-WQWE Evo1 GSR (and RS?) with front LSD Yes 3.909
W5M33-2-WQYE Evo1 RS non LSD No 3.909
