Top mounted intercooler, very short route and hood scooped! *UPDATE*
misterfixit
Midlands, UK
Just a silly question.
But first I really like the idea and your go so far.
When you are running at speed could you run air over the intercooler the other way? Like a duct from where the foglight is or out the side behind the headlight.
Is there a way you could duct from underneath, then up and over the hood? Something similar to the side mount coolers on group 'c' cars. Hot air goes upwards naturally, look at the hood on a 205t16 where the air is drawn back and up through. Second effect would be air rushing over the hood would pull air up through the core.
Rich
TomN
North Port, Fl
Quoting rdomeck:
^ It is. But it's no different than most others out there and I don't feel like that's my huge heat issue....Maybe some, but not the 150 degree's that I am seeing!
Yes many do it this way. But it's wrong. It's why many struggle to do what only a few can. Cause they say well most others do this.
I garantee you if you have the intake pipe go over the frame rail and down into the fender and pull fresh air from there you will see a differance. Will it alone get you where you want intake temp wise? Maybe not but it's a start towards doing it right.
I like your idea and think it could work with some adjustments. But pulling hot air from the engine bay is a bad start.
rdomeck
Indianapolis, In.
Quoting misterfixit:
Rich
Rich, With a lot more development I could. I thought about doing it this way when I first started, but liked the idea of a hood opening. I won't rule out the idea in the future, but would really like to be driving my car and know that I'm not beating the crap out of the inside with 150+ degree temps going into it!
rdomeck
Indianapolis, In.
This is what I ended up doing.
Hopefully I will have a chance to develop the top mount option down the road.
Thanks for all the helpful input and encouragement!
James
Port richey Florida
If you ever plan on getting rid of the hood, make sure I'm first on the list.
rdomeck
Indianapolis, In.
The fresh air will be directed over to the air filter. I will build an air box to make all the cold air go directly to the filter element.
If there is enough interest I could take a mold of it and reproduce them. Would need at least ten people on board to make it worth the effort though!
rdomeck
Indianapolis, In.
Update. It seems like a lot of people ask about throttle response to the side mount vs the front mount. I really cannot tell a difference. Intake temps are very low compared to the side mount. I am not seeing anything above 93 degrees on an 85 degree day with my EVO 9 set up. I'm glad I tried something different and I still really like the way the hood looks. I will make an air box for the intake to pull air in this winter if I'm not driving the car for some reason......Now I just need to learn this whole tuning thing and get it running right!
