tein or hotbits?
Whoodoo
Binghamton, NY
Im gonna get some camber plates and it looks like I have a choice between tein or hotbits. The thing is, the hotbits plates will be ~50 bucks more. Are they worth that much more? I really like the idea of supporting a smaller, more local company but $50 bucks is quite a bit more expensive. Any input is appreciated.
jepherz
KC, Missouri
I think the Tein plates are Aluminum, aren't they? The Hotbits I have are steel. That doesn't really say much about durability without knowing the thicknesses but I have seen bent up Cusco aluminum plates.
$50 is a lot of money....
Save $50 and get the Teins. Hotbits coilovers are better, but the top plate differences between the two brands are negligible, IMO.
*edit*
Jepherz beat me to the reply and I didn't realize the Hotbits top plates were steel. That said, my Tein plates are doing well after seven years and I can't say I've ever seen a set that were bent due to being aluminum.
Whoodoo
Binghamton, NY
Quoting jepherz:
I don't know if that was sarcasm or not... How much adjustment is possible with the hotbits. How much with the teins?
The Teins on my car allow for -2° camber. Camber bolts can be used to add additional negative camber as I've done to get about -2.4°.
jepherz
KC, Missouri
Quoting Whoodoo:
Quoting jepherz:
Nope, not sarcasm. $50 is a lot of money when you're talking about an additional 50% cost. I think in terms of adjust ability, they are going to be about the same.
I've never heard of anyone having any bending issues with the teins, and like I said, I only saw it in cuscos. I'd personally get the Teins if I were you.
jasonvr4
sydney NSW
Hi,
Well i tossed up on the thought of both of the questioned suspension set ups.
And i ended up buying BC Coilovers and I am so so happy with them the handiling is outstanding
I believe they are better than Tein and Hotbits --- Have a look at them you wont be dissapointed !!
Jasonvr4
Sydney
Whoodoo
Binghamton, NY
Im not talking about a whole coilover setup, just the front camber plates. I will be running evo struts and springs and will need to have camber adjustment when I either cut the front springs or get some espelirs. Does BC sell camber plates?
jepherz
KC, Missouri
Quoting jasonvr4:
Hi,
Jasonvr4
Sydney
What exactly makes you say they are better than Hotbits or Teins?
fivestardsm
Middle, Michigan
The price is the only thing I would say would be better.
belize1334
Bozeman, MT
FWIW you can also get GVR-4 specific KSport camber plates. Also, Ground-Control makes a really nice looking DSM camber plate that has four slotted bolt holes for caster adjustability. I've spoken with their tech guy who assures me that they also work on the E39A chassis with the sacrifice that you have to use up some of the caster "room" in order to get the bolts to fit our elliptical bolt pattern.
Olson
Moreno Valley CA
Quoting jasonvr4:
Hi,
Jasonvr4
Sydney
Looks dont mean squat to me. valveing and spring matching are the biggest things. Jap tend to ramp there rebound and damping up so you get more of a jaring feeling out of it. While the hot bit that are on my car fell nice and smooth, also at the same time you can crank up the adjustment on them and they handle a hell of alot better than teins and ksports. Ive driven all three setups at thunderhill and i will say again hotbit all the way.
On to the camper plates i can get -3 degrees out of my hotbit camber plates. More camber is good on a front heavy car like ours. also tire size makes a diffrence on how much camber you want to run.
Jake
grocery_getter
Quoting turbowop:
Wop, I might not remember this right but I think I've gotten up to around -3.5deg of camber on my Tein plates a while ago without using any camber bolt.
I don't know how. Mine are maxed out. /ubbthreads/images/graemlins/dunno.gif
Notice that the center bearing is as far in as it will go:
belize1334
Bozeman, MT
^^ Sorry for the off-topic post but where'd you get that strut tower brace?
It's just a Cusco bar. I bought it used and the end brackets were in pretty rough shape, so I had them powdercoated to match the valve cover.
AWDnot2
Wheeling WV
Now that is one clean engine bay!
Whoodoo
Binghamton, NY
So I was looking around and trying to compare the available camber plates for our e39a's and apparently Tein has invented a new material... Their mounts are made from 'Ultra Duraluminum A2017S-4'. What the hell is that? If you google it, the only hits you get are tein related. Anyone know what they hell this stuff is? How have all your tein mounts been holding up?
