taillights
I wanted to know is there a relay or something thats in between the taillight switch and the rear lights. they wont come on when i step on the brake: I changed the switch, checked the fuses, i also checked to see if i'm getting proper voltage, I'm only getting .05 volts at the connecter lmk I NEED LIGHTS /ubbthreads/images/graemlins/banghead.gif
Hertz
Chicago, IL
Do you have taillights when the headlights are on?
There is a 10amp fuse and relay underhood for the tails. Reference the diagram on the cover.
I had a similar problem when i was installing my double den DVD in mine, I accidently dropped the hot wire an it tuched the ground.. I lost interior lights, head lights, and tial lights.. turns out it was just the tail light fuse on the fuse block under the hood... Fixed it all up. Try starting there
