t/e/l sway bars
Jesh
Soldotna, Alaska
I'm sure someone knows but are the sway bars on a T/E/L the same as the vr4? thanks in advance.
broxma
San Antonio Tx
The front, probably.
The rear, I just installed an aftermarket TEL swaybar on the rear of 379 tonight. I do not have AWS and have a TEL rear subframe, Diff, axles, etc. I do not think it would clear the AWS rack if it were still there.
/brox
SouthCaliVR4
North county San Diego
front is the same & fit's fine. rear will fit only if rear steer has been removed. Pretty much as stated but thought I would confirm.
Jesh
Soldotna, Alaska
898 lost its aws a while back so that won't be and issue, thanks for the info guys /ubbthreads/images/graemlins/smile.gif
