Sway bar bushings - what/where?
EfiniX
portland, or
For the moment, I'm just looking at doing the front sway bar bushings as I know them to be shot. I figure new endlinks aren't a bad idea either.
Are the bushings in the front the same as other 1g AWD's, or are they VR4-specific?
Any recommendations?
VR6Eater
Bristol, WI
Whitelinesuspensionparts.com or PM bobdole.
The 1G and GVR4 should be the same.
Wizardawd
Franklin, NC
The 1g bushings/sway bar is 21mm. The GVR4 front bar is 22mm. I used the 1g bushings from energy suspension and they fit with a bit of cussing.
Wiz
idreamidrive
Murray, KY
Don't get the white line universal 22mm bushing as it will not fit. I just found this out.
These should fit click
Or you could order some from jnztuning.
KiNgMaRtY
Corona, CA
Quoting Wizardawd:
Wiz
This is also what I did before I purchased a Whiteline front bar.
VR6Eater
Bristol, WI
I called JNZ for a set of 22mm whiteline bushings and they said Whiteline isn't making them anymore. Whiteline said the same thing. I bought a set of the universal 22mm and sanded and ground on them and and by the time i made them fit they were to thin. If anyone finds a line on th e22mm whiteline ones let me know. Mine are worn out bad. Or i might have to change front sway bars I guess?
idreamidrive
Murray, KY
See my post above. From what I gather with the old posts and part numbers, white line never made front sway bar bushings and outsourced it to the above company.
Drew84
Peabody, Ma
Quoting idreamidrive:
Thanks for the info on these, I bought stock ones from JNZ because I couldn't find poly ones. Now I can get some poly ones instead.
idreamidrive
Murray, KY
I did the same thing in getting the oem from jnztuning. Then found those after doing a through search here, but our search function isn't the greatest
ApexHunter
Marysville, WA
What is the problem? Bracket?
Drew84
Peabody, Ma
The universal 22 mm bushings are too thick to fit in the OEM bracket. I tried some energy suspension ones and found the same problem. I discovered the originals were junk when I did my steering rack last spring.
VR6Eater
Bristol, WI
I ordered a set from the post above. 4-6 weeks until arrival. I'll let you guys know if they are the same as the Whiteline when I get them.
idreamidrive
Murray, KY
Quoting ApexHunter:
too thick and not wide enough to fit in the bracket.
