Starting delay...
SleepinGVR4
Danville, Pennsylvania
This just started happening when it got real cold out.
In the morning when I start my car sometimes I have to hold the key to the ignition position for 5 seconds before the car will start to turn over.
My car always starts but only after sitting all night does it have a delay.
Is this the little starting gear on the starter getting stuck, before it makes contact with the flywheel?
G
zompton
What weight oil do you have installed?
Tommyd
Fishkill, NY
I have the same thing happening. Once the engine bay is warm or it's warmer than 50 degrees it's fine. No idea what's causing it though
G
zompton
Change to 5w 30.
G
zompton
Ok.
EMX5636
Bucks County, PA
You mean the starter doesn't even start to turn for up to 5 seconds after turning the key? If so, could be either the starter relay, or the ignition switch on it's way out. We have a couple horn relays on trucks at work that seem to shrink the contacts (almost like a bi-metallic spring) in the cold and either turn the horn on, or not have it work until the engine bay/fuse box heats up.
donkeylips
Rochester, NY
My Galant GSX behaves similarly. But rather than holding it for 5 seconds, it's sort of random if it wants to crank. 70% of the time it doesn't. Eventually it does. I've tried manually turning the engine to a different position to try to give it an easier time. Can't remember if that helped - I always figured it was a grounding issue. One of the first things I'll have to fix in the spring.
