LOTS of GREAT PARTS - Unused/Used; Just updated with new listings and/or pics. So visit this ad often and send a PM with questions or an offer (include your ZIP CODE and PAYMENT METHOD). Will add parts to list as other items are sorted. TIA.
*** Be sure to check out other nice parts for sale
here >>> click
and here >>> click
I recently settled on the direction I want to go with the car and these are not or may not be part of the plans.
PARTS FOR SALE:
* Deep candy apple red valve cover $60
* Unorthodox Racing underdrive pulley, blue anodized $45
* HKS Power Flo mas/air filter housing $95
* HKS turbo timer, old school style $50
* Greddy EGT gauge (large, ~60mm), complete with Data Link Unit, harness, and probe $85
* Omori boost and oil pressure gauges (small, ~52mm)
* VDO boost gauge (~52mm)
* Stage 3 1G head - superbly ported, polished & prepped by Paulus - the mechanical engr guru with F1 know how, formerly of AEBS when they campaigned a 6 sec Focus; he was also a consultant for the early cylinder head designs used by Bent Rau. Head details incl: 1mm over SS valves, dual springs, titanium retainers, 3G lifters; man this will be hard to let go, send PM for full details... $1075 or best reasonable offer
* Trust/RRE front ($115) and rear ($95) strut/shock tower stabilizer bars
* OEM/Denso 450cc injectors (CLEANED & FLOW TESTED by RC Engineering) $145
* OEM/Denso 450cc injectors (used) $50
* JDM GVR4 headlight assembly $145 - Version with NO city lights; lenses are great and includes all 4 bulb covers; NO bubbling of rear reflective surfaces; NO peeling/stripping of black paint on top; NO broken tabs or clips. These use H3/H4 bulbs which are brighter than than US factory 9006/9007 bulbs. The H3/H4 bulbs did not come with them so these do not come with pigtails. However it is easy to splice in your factory harness. A 3 prong pigtail can be purchased from National Auto Parts, Autozone, Pep Boys, Advanced Auto, etc. Get the "high amperage" (sealed) one for under $15/pair. You'll need 2 pairs.
* GVR4 clutch master cylinder assembly MB012660, new/unused $95
* 90 DSM oil filter assembly for those wanting to use external oil cooler $40
* 2g water pipe, modded to accommodate 20G and similar larger turbos
* 2g t-stat housing and coolant neck
* 2g stock head
* 1g stock head
* GVR4 coil pack
* GVR4/1G starter
PICS (lots of NEW ones added)
SOLD:
PTT (6bolt) twin disc clutch package, incl FP crank bolts, dedicated PTT-modded TO bearing, all jobwork, literature & reference docs, unused since full PTT rebuild
ACT2600 PP (MB010X) + street disc ~1.5k-2k miles
HKS 264/272 cams ~7k-8k miles
Super cool Sparco footrest, clutch, brake and gas pedals (brushed silver finish) & blk leather shift knob, all new/unused
JDM GVR4 grille with "Full Time 4WD VCU & Center Diff" badge
JDM clear corners, both sets
93 headlights
USDM GVR4 driver side fog light
USDM GVR4 passenger side fog light
GVR4 stock cat and downpipe
GVR4 92 center tail light & license plate section assembly
Magnecor Competition plug wires - all sets gone
Denso 450cc injectors, 1 set
FIC 1450cc Bluemax injectors
FIC injectors 1000cc injectors
RC Engineering 725cc injectors
RC Engineering 550cc injectors
Noltec polyurethane bushings - N92170 (rear mustache), N92146 (rear subframe), new/unused; please note that N92146 are ~3mm too small and need to be shimmed (priced accordingly)
Whiteline polyurethane bushings - KCA365 (rear camber bushings), KCA321 [Front Lower Control Arm REAR Bushings (Caster adjustable)], both new/unused
Energy suspension bushings (Kit): 5-4105G (Front subframe), Rear control arm, 7057 [Front Lower Control Arm REAR Bushings (NON-Caster adjustable)]
here >>> click
and here >>> click
PARTS FOR SALE:
* 2g stock head
* 1g stock head
* GVR4 coil pack
* GVR4/1G starter
SOLD:
93 headlights
