So where have I been? Been quiet.
Mark
Naperville, IL
If anyone remembers lst year I did a best of 10.2 w/the auto galant and was having some issues that day w/the car smoking and really not running good..
Turn to wednesday finally got time to check it out bring it to the shop and find out whats up.. Well found something interesting.. Blew HKS MLS, piston was messed up.. This is why oh and hose are oliver rods so they are not that cheap =)
[/URL]
[/URL]
So turns out I ran a 10.2 w/a a bent rod =) and low compression on #2... So I ordered new rods, HG, and etc.. Also amd doing a tube frame crossmemeber up front cleaning up some wiring and getting ready for rest of the year!
14u2nV
Agency/St. Joe, MO
Why on earth did you install a bent rod? /ubbthreads/images/graemlins/dunno.gif
/ubbthreads/images/graemlins/tongue.gif Gonna shoot for nines when all your rods are straight? /ubbthreads/images/graemlins/grin.gif
fivestardsm
Middle, Michigan
OUCH!!!
Nice paper weight tho! /ubbthreads/images/graemlins/grin.gif
ktmrider
Tempe, AZ
Hey Mark, that would make a great demo tool for "High Cylinder Pressure and Your Engine Internals".
Glad to see spring is bringing the GVR4 out!
curtis
Clarksville TN
I've got an old eagle rod I'm going to make into a shift handle but this does you no good since your auto now just put a nail in the shop wall and dedicate to the God of Speed. /ubbthreads/images/graemlins/grin.gif
Quoting Aspod:
^^^Same here. Thats crazy.
Same here. Doesn't make sense with the force directions in the engine.
Barnes
Richland, WA
I guess it could have just buckled due to so much force. Would explain the way it's bent. See: Beam Theory.
Terry Posten
Davenport, Iowa USA
I think Jon's on to something.
Good thing it did not cause any damage and you found it before it was too late.
Quoting iceman69510:
Quoting Aspod:
How often do things happen to our cars that we have to step back and say wait.. that doesn't make sense.
Mark
Naperville, IL
Quoting Jonvr4:
water in the cylinder would cause that kind of force, and he did have a bad hg.
The rod damaged the piston the way was bent which damaged the headgasket which caused it to blow. The block is fine whats awesome =) i have a new set of rods and pistons on the way.. The bearing looks brand new ws just a freak occurance.
That doesn't explain root cause of the rod bending in the first place.
Barnes
Richland, WA
I'm just saying that's what would have caused the rod to deform that way. I'm not saying what caused that pressure. /ubbthreads/images/graemlins/crazy.gif
Brianawd
Portland OR,
Thats like the 3rd or 4th bent oliver rod I have seen in the last few years. My friend paul did that same thing on his evo. I have also seen a few from 2jz guys. I am starting to think they are junk.
