Rotor and Dust Removal?
711
Active member
Neverland
Do I need to remove the axle nut to remove the rotor and dust shield? /ubbthreads/images/graemlins/dunno.gif
Thanks!
Axle nut is not required to remove the rotor.
But to remove the dust shield, everything has to come apart and even the wheel bearing need to be pressed out if I recall.
89Mirageman
Stantonsburg, NC
Unless you don't plan to put it back on. Then tin snips and some pliers to bend it off will work.
EgonOlsen
Denmark, Europe.
I think we usually just cut a "vedge" at the bottom of the new shield, so you can put it on without removing everything.
transparentdsm
Cherry Hill, NJ
can you take pictures of this? i would like to see as i just recently repainted everything and the only way i could see to get the dust shield on/off is to remove everything and press the hub out of the knuckle.
Quoting EgonOlsen:
I did not modify my fronts like this, but I did to the rears (he means "wedge").
89Mirageman
Stantonsburg, NC
These wrap around the knuckle though, press fit. I would think if you cut a section out to install them they would be loose and eventually move around or even fall off. I know the rears have a bolt holding them on though.
The fronts are also held in place by the caliper bolts when mounted.
EgonOlsen
Denmark, Europe.
Yes what he said, there are bolts holding them in place, so cutting it in the bottom dont really matter. They accept it at inspection too and they are pretty harsh here.
Not the best drawing, but you get the idea, cut the red lines. The holes are where the bolts are if im not mistaken.
EgonOlsen
Denmark, Europe.
I actually only think the 2 lower ones are for bolts, not sure. Been a while since I changed one.
yes they hold fine, its the caliber bolts, if they fall off. well..... :p
