Removing rear wheel bearings from axle shaft?
Romanova
Cypress, TX
Bought a 8" puller from HF, thought the 'feet' on the puller are shaped in such a way that they don't grab onto the bottom of the bearing. Any suggestions or recommendations? Going to see if AutoZone's tool rental program has anything that will work...
mitsuturbo
Near Seattle, Washington
If you're talking about what i think you're talking about, i think i used a press when i did that job before.
Muskrat
Lexington, KY
Dead blow hammer on the stub?
Regular hammer and a piece of wood?
You're replacing the wheel bearing right?
Romanova
Cypress, TX
attachment.php
Thats what I am trying to do... I guess a bearing seperator and the press might work? Not sure what to secure the bearing to to hammer it out....
jepherz
KC, Missouri
I was able to do mine with a bearing puller. They are all such different shapes that it's a toss up.
bazeng
Melbourne, Australia
There is a thread somewhere where I put a bunch of pics up doin this... Anyway, I used one of those flat sandwich type pullers... Came off easy!
I think I put mine in the vise (bearing against the vise jaws) studs down like you have it, and hit the end of the shaft with a dead blow hammer.
Struc
Oconomowoc, WI
Did you try flipping the puller jaws around the other way? I *just* got done doing it in my garage a few minutes ago, and needed to flip my jaws around the other way so they fit properly under the bearing & dust cap. At least for my passenger side. The drivers side bearings & abs ring stayed in my control arm when I pulled that one apart. /ubbthreads/images/graemlins/banghead.gif
Adorsey
mass
That way will work if you switch the arms around, and if you have access to a impact driver, it will come off. The new bearing goes on easier than getting it off so just have at it and wack it off if you need to.
**Hey! There is an impact on there...
Romanova
Cypress, TX
Quoting Romanova:
Looks like that is what I need...
Just a follow up... that HF bearing puller worked super slick and made quick work of the rear shaft bearings and covers. Very pleased with the purchase, which was $50 after 20% off.
And the HF three jaw puller wasn't worth a sh*t. Waste of $10.
