Question about manual rack and keeping aws.
cupajoe
Cocoa, FL
I'd like to delete p/s but I plan on keeping aws if possible. Is this possible or will this cause an interferance with my aws? Any insight would be great. Thanks.
seeing as how the rear pumps high pressure lines are fed from the rack int eh front. im going to venture out and say no?
cupajoe
Cocoa, FL
Thank you, just was unsure if it ran off the rack. Guess I'll have some more research and thinking to do when I do my build.
Brunoboy
San Bruno,CA Home of SFO
Manual rack deletes the 4ws fittings.
cupajoe
Cocoa, FL
Thanks, I'll be doing a full engine build as soon as I get to my first duty station. Since I can't just do a p/s delete I'll end up doing a ground up rebuild. So guess I'll wait a little bit and do a full p/s delete,4bolt, abs delete, and 5 lug swap If I cant get 4 lug non abs(unsure if there is any?)
