Power steering
Hi, I'm having trouble with my power steering, at low revs my steering his hard and noisy where as at higher revs (about 15000rpm) the steering is perfectly fine. Any ideas what might be causing this problem? Thanks!!
ktmrider
Tempe, AZ
Hit the VFAQ, there is a pressure control valve inside the pump that is causing your problem.
And bookmark the VFAQ whilst you're in there....
