Paint or powdercoat calipers?
blacksheep
Urbandale, Iowa 50323
Has anyone painted their calipers with the brush-on stuff or spray on? Does it hold up and look professional?
I found a vendor who offers re-built powdercoated calipers for 330 for the fronts and about same for the rear and less if I sent mine in. Hard part is I don't know how I will keep the lines from draining when I take mine off and send it in. I don't want to bench bleed the master. I screwed up on my integra once and it was an awful experience.
Now I can also just buy remans from rock auto and paint them myself, but I don't know if this caliper paint will hold up. I could get coated locally, but I think I would have to completely disassemble to do that and pointless buying a reman one for that. Also, I have not re-built calipers and am frankly nervous about my skills.
I won't be painting them ricey red, just silver or black is what I planned.
Thanks!
Do not plan on taking the calipers apart. rebuilding calipers (especially dual pistons) is not for the faint of heart. You need to know what your doing to get the seals and boots in right. The rears are even more fun as the parking brake is incorporated. As for paint, I can't help you there.
QnzMostWanted
Orlando, FL
the caliper paint they sell holds up pretty well, on my last car it held for 9 years before i sold the car, so i'd say u shouldnt have a problem, and these were sprayed on , not brushed
blacksheep
Thanks for the feedback, I watched this jafro video - makes it look easy why I considered it even...http://www.youtube.com/watch?v=h4_lE8Dmeqw
EHmotorsports
Beaverton
Just make sure you clean them spotless and degrease them good. Any dust,grime or oils will make the paint flake off.
4Grim
Orlando FL
The calipers on my GVR4 were brushed painted with that caliper paint kit from Advanced Auto. Still holding up and still has that shiny luster to it.
EHmotorsports
Beaverton
And after they are painted. Never use wheel cleaner with acids in it. Or castrol super clean. It will dull the glossiness.
Romanova
Cypress, TX
I got 4 rebuilt calipers from Centric from Rock Auto... very impressed with them. If that matters lol
G
zompton
Or brake parts cleaner.
blacksheep
Quoting Romanova:
5.0 - that's what I am looking at buying and painting, brah!
I actually painted one front caliper with Rustoleum and powdercoated one as a test. Both lost paint on the back sides where the actual fluid is housed in the caliper, likely because of the heat. I have never tried the caliper paint but probably will next time.
matt92vr4
Venice, FL
I've had good success with the spray on paint. Bad results with the brush
89Mirageman
Stantonsburg, NC
I took my calipers apart (not the seals and dust boots though) and wirebrushed them really well. Then I painted them with cast grey duplicolor engine paint. They look new and are holding up great.
There is a very brief "how-to" in my summit wagon build thread. Maybe it'll help. click
kama1
q.c. philippines
I used regular silver spray paint on the blue amg,its been 3 years,its dirty now but didnt flake or peel.
Just cleaned the caliper with soap, taped over the dust boots and sprayed.
blacksheep
Quoting 89Mirageman:
Thanks, but link does not work for me /ubbthreads/images/graemlins/frown.gif
PJGross
Lake Orion, MI
On my Impala SS I used the spray on caliper paint in red and it lasted 8 winters in Michigan. After having the V with Brembos I would never paint cast iron calipers any color but black or silver but anyway, the spray on paint worked. I wire brushed and toothbrushed with brake cleaner, then mineral spirits. I took them off and plugged the line with a rubber cork shaped stopper while painting. Minimal fluid loss, didn't lose the master cyl.
-PJ
