Overheating
Illinoisinc
Active member
Chicago, IL
Well good morning everyone. New gallant vr4 guy here ( new piston guy as well, been in the rotary world all my life )
Just purchased the car and it is overheating.
I have changed the Thermostat, Radiator cap, flushed the coolant ( well it spit 90% of it out lol )
I noticed when it was overheating the reservoir was just being pushed out.
Can it be the Head Gasket?
Please help me out guys.
Thanks
Do the fans run
Illinoisinc
Active member
Chicago, IL
Yes the fan is running.
May be head gasket if you are getting pressure pushing out coolant.
Illinoisinc
Active member
Chicago, IL
Dammit!!! That is the last thing that I want to do!! lmfao
transparentdsm
Cherry Hill, NJ
head gasket isn't all to hard to do in these cars. find a local who knows what he is doing and you two can have it done in a few hours.
Illinoisinc
Active member
Chicago, IL
is it really??? sh*t.
transparentdsm
Cherry Hill, NJ
yeah. do you have any machine shops by you? id also set it up so you can have the head resurfaced at the shop after you remove the head that or buy a spare head and have that all prepped and ready to go before you start. last time i did one it took me 6 hours and 7 beers.
Illinoisinc
Active member
Chicago, IL
No I don't know what shops would do it but Ill ask
CutlassJim
Manchester, NH
You've got AMS in that area.......
If the engine is original with over 150k then at a MINIMUM I would replace the valve seals. Finding another head and freshening it up with stock valves, viton seals and maybe a set of Evo beehive springs would extend the life of that engine for another 150k miles and with a set of ARP head studs it's ready for any mods you want to throw at it.
Illinoisinc
Active member
Chicago, IL
Yeah they also charge a dick and leg from what I hear lol.
But none the less you are right.
Quoting iceman69510:
Not always. If the coolant has a low boiling point then once it boils the expansion rate of the coolant rises. The rad cap opens to release pressure and then the boiling coolant is pushed out the reservoir due to the expansion.
More info on the car would be nice. Once I had a 1g that was overheating. Everything was fine, turned out the owner wired his fans backwards. The air was being pushed to the front of the car.
Illinoisinc
Active member
Chicago, IL
It has a 1g motor.
Previous owner stated that it had a new head gasket, rebuilt head. so that I why I am confused.
OldHairyBastard
Northern Chicagoland Area
It can also be the head itself. I've had a motor not blow the head gasket but I did have the aluminum on the head develop tiny holes that would build up pressure in the coolant system and pop radiator hoses. The head gasket was good but cylinder one had the heat damage in the aluminum on the head. If I drove nice everything was fine but hitting boost a few times in a row and POP went a radiator hose. I switched to a new gasket and fresh head and all was right with the Diamond Star Gods. It could also be both.
Coltsfan
Tonawanda
It could also be as simple as a bad radiator cap. The only thing preventing the coolant from boiling when it hits 212F (lower as you go above sea level) is the fact that it's under pressure. I cap that no longer holds pressure, will boil over every time.
Edit: But you have a new radiator cap. /ubbthreads/images/graemlins/idea.gif
I have a tester that percolates the gas from the cooling system through a blue liquid. If there is CO or CO2 (don't remember which) in the cooling system, the fluid changes to a bright yellow. I would see if you can get someone to test it with that, unless you are 100% sure everything else in the cooling system is up to par, and that the ignition timing is spot on.
When the fan kicks on, do you feel hot air being drawn from the radiator?
Illinoisinc
Active member
Chicago, IL
I will try that out today. I greatly appreciate it seriously guys. I feel like im a big bother here.
I need to learn these motors quick lmfao
Illinoisinc
Active member
Chicago, IL
Also I just called AMS and was told that they don't work on any DSM's..... That's bogus lol
Tell them it's not a DSM. Truth. /ubbthreads/images/graemlins/wink.gif
Illinoisinc
Active member
Chicago, IL
I actually said Galant vr4 lol..
G
zompton
I would check your timing first.
