Oil light flickers
mrbonnell
Active member
Fort Myers, FL
278 of 2000 here. Oil light started to slightly flicker on/off, then eventually illuminated fully. Turns off at higher rpms. Checked vfaq for any clues or answer and came up empty. A fellow DSM'r told me it could be and oil sender/switch. Just checking to make sure if there is a possibility that it could be anything else. Dip stick reads full, oil pressure good.
How have you verified the oil pressure is good?
It likely it is just the oil pressure switch or a loose connection to it.
fuel
Toronto, ON, Canada
I would get an oil pressure gauge on there ASAP to monitor the oil pressure.
I had a similar issue with my parents old 5th gen Galant 2.0 Super Saloon, they've had it since near new, had about 100k miles on it and would get a service every 6 months without fail, which often only 2-3000 miles had been travelled between services. Needless to say the engine was pristine inside with no oil issues whatsoever. One day the oil light started flickering on, more so when the engine was idling or in drive and sitting at the lights. It turned out to be a faulty oil pressure switch. $5 later and it was sorted!
Just do what I do and put a piece of tape over the light, out of sight out of mind /ubbthreads/images/graemlins/rofl.gif
Sorry had to. Try jiggling the wire while sombody keeps an eye on the light, if it flickers then tighten up the plug, that's all that was wrong with a Cordia Turbo I had.
mrbonnell
Active member
Fort Myers, FL
Quoting Darksyne:
I have an after market oil pressure gauge and I have to believe it reads true. The dip stick read full. I will def check out the oil pressure switch but im also curious are they known to leak a little oil?
mrbonnell
Active member
Fort Myers, FL
Quoting Justin_Cosgrove:
Haha like it never came on! I love it, do you recommend black electrical tape or duck tape for this repiar? lol
HHIVR4
Hilton Head Island SC
If you have the stock water cooled oil filter housing they are known to leak because they tend to vibrate loose.You can disassemble,clean and loctite and I highly recommend it.Or swap to a 90 DSM one and have the advantage of an oil cooler.
RayH
NJ
When my pressure sender went bad it started to flicker on only when oil pressure was the lowest which was when the engine is warmed up and idling. As the sender got worse the rpms at which it started coming on got higher. I think what happens is as the sender goes bad the threshold pressure at which it comes on slowly goes up and it eventually reaches the lowest pressure that the engine run at and starts flickering on.
mrbonnell
Active member
Fort Myers, FL
Quoting HHIVR4:
Im assuming the 90 DSM bolts right up or is there any modding involved?
mrbonnell
Active member
Fort Myers, FL
Quoting RayH:
This sounds exactly like my problem, thanks for all the help everyone. Is there anyway that I can say this thread so that i can reference it at a later date in case this problem comes up again?
mrbonnell
Active member
Fort Myers, FL
Hey to the last poster, I accidentally deleted your post. My appologies please post again.
Actualy I wasn't intirely joking /ubbthreads/images/graemlins/tongue.gif I used a playing card over my fuel gauge during the hour drive home from Polytech as it was too discerning driving with the fuel light on /ubbthreads/images/graemlins/grin.gif did that most days. Never stopped.
