Oil cooler
Lucas03ES
Boulder City, NV
So I have a 90 OFH on my car, and I was going to be mounting this B&M cooler with braided steel lines and such, but I cannot find a suitable area to mount it to. I saw Terry Posten's mount where the ABS unit used to be, but this cooler seems a bit too wide to fit in that spot. I was also going to attach it to the front of the passenger side of the AC condenser, but my lines are not long enough. What about the back side of the condenser (civic rad)? Would that be too hot of a location? Could I possible mount it where the AC fan is, and put a different fan on the back side of it? What about on the back side of my ETS fmic? Im just looking for an optimal spot, and if none of these are auitable, would it cause me any major problems to just bypass it?
WaRrIoRs16
Ferndale, WA
If you searched, I just posted a thread about where I put mine. No, I do not have A/C, but I have my radiator right where the condensor was. So, to answer one of your questions, you can put the oil cooler where the fan was. I even included many pictures in my thread. Have a look. B&M Oil Cooler Mounting
Lucas03ES
Boulder City, NV
I did search.
I have A/C.
I ended up removing my power steering cooler and mounted it to the back side of my ETS front mount.
