oil cooler install questions?
turbophein
mass
i have a summit oil cooler i am trying to install in the vr4. i went to the local parts store and they can't find anything that will fit my application.
i have a 90 OFH, the lines coming from the cooler are -8 with a female end earls fitting. i somehow need to tap the -8 into the filter housing. at first i wanted a banjo fitting that had the -8 threads on the end of it and couldn't find one, then i looked for a male to male adapter fitting to just screw into the housing and couldn't find that either.
i think the stock banjo bolt is a m16 x1.50 thread right? and i have a -8 braided line.
so i either need a banjo fitting that is M16 and has -8 threads on the end or the M16 x1.50 to -8 adapter.
any help would be great
turbophein
mass
just found these click
i was just assuming my line was -8an from a pic i saw in the earls catalog, but i am not sure, and they don't even carry a -8 adapter.
i tried googling to find the diameter of a -6 or -8 line and got a bunch of useless fishing links
Edit: -6an is 3/8" line
-8an is 1/2" line
mooserage
Seattle, WA
I think this is answered, but since I have the paper right next to me,it is an 8an male to 16mmx1.5mm male (Summit Aeroquip part # FBM2243)
-shamus
Edit: The above link to earl's stuff is for o-ringed flare fitting, not what you need. You want this: click
turbophein
mass
yes i was worried about that o-ring! thanks for the info, much appreciated!!!
TylerAdamson
Iowa City, Iowa
9919EFJ is the EARLS part number for the m16x1.5 to -8 fitting, and its $7.99 from AN Plumbing. As for what fitting to use, that would depend on where you were going to mount the Oil Cooler unit. I would think that a 90* fitting would work for most locations though.
raptorWagon
Oak Harbor, WA
My question from what I've read in other threads..is the general consensus to use crush washers with the AN fittings to prevent leaks from the OFH housing and the stock 90' cooler if using one?
Copper washers along with a small amount of thread sealer. Forgot the name of the company, maybe staybond but arp has some too. Hasn't leaked a drop.
