if you are doing the swap, then the year of your car doesnt matter, just make sure the year of the ecu/engine sensors/wire harness match. you can use a TEL wire harness as well, there are some minor differences. but it should work easily, there are a lot of differences with the 1990 TEL so I would just be safe and use the 91-94. but if you get a vr4 harness then it should fit perfectly. It just comes down to a matter of what you have available. If you already have a 1g harness then use it. if you already have a 1g ecu use it too.
So what do you already have? then we can tell you the cheapest/easiest way to get this done.
