New guy from Mass with a 4G63 Ram 50 and now a GVR4
89Mirageman
Stantonsburg, NC
I did the same thing on the last Colt that I built. I went way overboard detailing stuff that was completely blocked from site once the engine was back in. Still gave me a sense of accomplishment knowing that I did my best though. Your car is looking great!
4g63mightymax
MA
Thanks! I am definitely getting a little crazy with painting some of these brackets and things, but it will be really nice knowing that 1803/2000 will be one of the nicer ones out there!
If all goes well, I should be able to get the dash installed this weekend. I'm quite pumped for that because I have never seen a dash installed on this car!
4g63mightymax
MA
Tada! Dash is bolted in.
To answer your question: I'm going to assemble it some more so that I don't have 10,000 loose parts in my garage anymore, and then I'll sell it. The final status of it will depend on when I get a good $ offer/trade! /ubbthreads/images/graemlins/smile.gif Until that happens, I will likely keep building it.
4g63mightymax
MA
Soon.
the_underdog
Knoxville, TN
All I can continue to say in this thread is "wow, just wow!"
4g63mightymax
MA
I am finally wrapping up my major house/life projects for the summer, which means I can exist again. I apologize for the delay, and leaving you on the edge of your seat.
This week I got my flywheel machined so that I can finally throw the engine and trans together and stuff them into the car
I also glued the dash back together because it was lifting around the defrost vent. It worked surprisingly well. Gorilla Glue FTW.
Tonight I install the windshield! First time for me. Hope I don't smash it.
4g63mightymax
MA
Done. It was easier than I thought it would be.
Any buyers yet? /ubbthreads/images/graemlins/smile.gif I want to build something from the 1930's.
MellowVR4
Milwaukee, Wi
Nice work, almost their. /ubbthreads/images/graemlins/applause.gif
4g63mightymax
MA
I checked my compression on the mystery engine last night.
150.130.150.100.
So then I did a leakage test. Here is the result. link
I am hoping that it may be due to the adjustable cam gears being misaligned.
Oh and here is a picture from last weekend.
4g63mightymax
MA
Pictures because that's what I do dogg.
Remove cams
Organize your stuff
Tap the spring caps to loosen the keepers
Remove the keepers
Go to 5 Guys and eat a cheeseburger.
Look at the valves #1
Open #1
Look at the valves #2
Open #2
Look at the valves #3
Open #3
Look at the valves #4
Open #4
Before
After
Cleaned, Lapped, Reinstalled.
New valve seals
Almost ready to reinstall!
Still need to torque errrthang.
Looks like you had the special "high compression" valves. /ubbthreads/images/graemlins/jawdrop.gif
BENE38A
New Zealand
you just lapped them right in, good that the seats were okay. what a mess
4g63mightymax
MA
Yeah, once all the carbon was removed, all looked great. I did replace two intake valves that were a little wonky looking, but overall, the head is probably the cleanest one I have owned. I should be able to get it back on the block tonight, which means I can recheck the compression and cylinder leakage. I can't wait!
4g63mightymax
MA
Great news!
Here are the compression numbers in order...
150 - 155 - 150 - 155
WINNING!
If all goes well, I will have the engine in the car and running in the next two weeks.
4g63mightymax
MA
Thanks! It is coming out pretty nice! I'll be thrilled when it is drivable again, because I don't believe it has been on the road since ~2001.
Small update:
- Engine cleaned
- Engine painted
- New rear main seal installed
4g63mightymax
MA
Small update:
- Has a forward facing oil filter housing now
- New windshield trim clips ordered because all the originals were missing/broken (shrug)
4g63mightymax
MA
Engine and trans is in...
