Motor Won't Turn Over
CarRacer
Shakopee, MN
Finished up swapping in the rebuilt motor today. Tried to get it fired up and didn't have any luck.
The starter just clicks. I pulled the starter and jumped power to it. Starter spun fine. I double checked my grounds and everything is fine.
I tried to turn the motor over with a breaker bar and it wouldn't budge. The starter is engaging, but the motor is bound up and will not turn. The motor turned over fine when I was doing the timing belt installation. I didn't try to rotate it after installing the tranny.
I've resigned myself to pulling the tranny and seeing if that frees it up. I think the game plan is to pull the tranny, get the downpipe back on and try firing up the motor without the transmission.
Any simple fixes I may be missing?
How you gonna fire up the motor without the transmission? That's what the starter mounts to. Unless you have a spare bell housing you can bolt on temporarily.
GVR4_1057
Brucetown VA
Does the clutch actuate properly? Did you change flywheels?
CarRacer
Shakopee, MN
Crap. You're right. Well, the motor doesn't turn over regardless, so it's coming out. I guess I'll just double check the clutch alignment with the tool and see what shakes out.
CarRacer
Shakopee, MN
New fidanza clutch and flywheel. Clutch did work, I freshly bled it with an air powered bleeder.
GVR4_1057
Brucetown VA
Could it be a FWD flywheel? /ubbthreads/images/graemlins/dunno.gif
CarRacer
Shakopee, MN
That's what I thought too at first. I tried turning over the motor with a breaker bar and it wouldn't budge.
Could a misaligned clutch disk caught between the pp and crank bind up the motor?
GVR4_1057
Brucetown VA
Maybe try loosening your transmission mounting bolts a bit and slide it 1/2" or so away from the engine and try to rotate it again.
Did you shim the clutch fork? I did this one time with to thick of a washer, and the fork locked the clutch in place.
CarRacer
Shakopee, MN
All good suggestions so far, I appreciate them.
I'm 110% positive the timing marks are correct. I also turned over the motor a number of times before installing the tranny. Very possible mistake though.
I honestly don't remember if I shimmer the pivot ball or not. I know I was on the fence about doing so. I purchased a new fork, so I think I figured I was good and didn't. I remember having the pivot ball out, so I may have put a washer in there. There's been a lot to keep track of in this build and it's happened over a long time period too.
Terry Posten
Davenport, Iowa USA
Did you spin the motor over after the flywheel was torqued down?
Maybe the disk is not sitting on the crank right.
fivestardsm
Middle, Michigan
Well did you leave the Balance Shafts in? If so, did you possibly leave your screwdiver or wahat ever in the inspection hole? Or possibly put a bolt that was to long?
Might want to check.
fivestardsm
Middle, Michigan
Also, did the motor spin freely when you rebuilt it? Did you rebuild it?
rgeier11
Chicago Suburbs, IL
Is the transmission in gear? /ubbthreads/images/graemlins/smile.gif
CarRacer
Shakopee, MN
I did rebuild the motor myself. Stock OEM type rebuild. Replaced rings and bearings. No balance shafts. I turned the motor while getting the timing belt installed. Turned over fine.
I didn't turn it over after installing tranny or clutch though. The motor did sit for a period of weeks after timing component install. I didn't touch the shifter cables at all, other than removing from the tranny mount.
I'm assuming something in the clutch/tranny installation is messed up.
I like it when someone posts about how they fixed a problem they had posted about for everyone else's future reference. Im sure it will help everyone in the long run and cut down on unnecessary posts.
