motor mount vibration?
adamvr4
skokie/ il
i installed my polyurethane motor mounts and it vibrates like hell inside the car. I understand it going to do that but someone had told me i could change, i think the rear or front mount back to stock and it will eliminate the vibration in the car. Is this true? If so, which mount?
autobahntom
Delaware
Did you change all four? For mine, the big vibration came with the mount by the timing belt. Leave the front and rear there as they take up the 'twist' by the motor when there is a load on it.
Tom
Gordian79
Bronx,NY
Leave front and rear in take out tranny and tbelt ones off.
True. The front and rear ones are attached to subframes...those subframes have rubber mounts of their own so it gives less vibration. the t-belt and tranny ones are bolted straight to the frame so they cause the most vibration
VR_IV_MR
Queens, NY
if you had to single out one of the motor mounts for being responsible for the most vibrations AT IDLE, which one would it be? part number?
iLLeffeKt vr-4
NYC
I was told that the transmission mount will make the car vibrate the most.
So I only did the front/rear/timing belt ones. Yes it vibrates but that's what happens with solid/stiff motor mounts.
