Mitsubishi Evo 1 GSR vs. Mitsubishi Galant VR4
alansupra94
Wayne,NJ
Does anyone know if they share similar parts like suspension and exhaust. Engine and transmission are similar (besides transmission having an LSD and rear end having a mechanical LSD).
idreamidrive
Murray, KY
Evo 1-3 is more like a 2g dsm. From what I have gathered, the trans will not fit in 1g cars, but the internals will.
raptorWagon
Oak Harbor, WA
The Evo 1-6 are built based on the Mirage sedan chassis, so they will have more things in common with those cars than a 2g dsm which was built based of the 7g Galant chassis.
strokin4dr
Savannah, GA
Quoting idreamidrive:
Evo 1-3 trans will bolt into 1g dsms/ vr4, but not the other way around. Vr4 trans will not bolt into evo 1-3.
gtluke
dirty jersey
I believe the evo 1-2 trans/rear was the same mechanically as the galant RS, the evo 3 had the LSD front and mechanical rear. These may have been options on the 1-2 but not positive. I kinda recall the evo 3 having a unique trans and transfer case setup that's not compatible with anything else.
I have an evo 2 rear end in my car. The pumpkin doens't fit, but all the internals do and it's the same LSD as a 4-bolt DSM. I have this because I have the GVR4 RS trans in my car and you need this matching rear ratio.
