Jacking Point For Motor
desant78
Clarksboro, NJ
Hey guys...here I am with another newb question.
I need to remove the motor mount on the driver side in order to attach the timing belt cover. Removal of EVERYTHING else has been easy, all that is left is the motor mount....
I in the past I have used a bottle jack to support the motor where I remove the motor mount from...I was wondering if anyone had any tips for our 4G63 motors? Never played with anything like this....suggestions please.
Thanks for the help!
TylerAdamson
Iowa City, Iowa
Oil pan would be correct. Or you could get an engine hoist and use the bracket above the power steering pump.
The_Big_Weave
Rapid City, SD
If you are worried about it just use a phone book I get one a year and that is all I use them for.
donniekak
surprise az
As mentioned above, the oil pan is fine, but put something between it and the jack to avoid denting it. It's possible to dent the pan into the oil pickup, and have oiling issues.
boostedinaz
Scottsdale, AZ
Quoting The_Big_Weave:
jb4
Hampton Roads
I always use a cut down 2x4 between the floor jack and oil pan.
desant78
Clarksboro, NJ
Quoting donniekak:
exactly what I am afraid of! thanks for the help everyone!
Quoting jb4:
You use a 2x4? I use a 2x6. No biggs. /ubbthreads/images/graemlins/keke.gif
i always jacked up on the oil pan with no issues, as long as your not picking the car up using the oil pan
toybreaker
iconoclast
^^^ He's wanting to use a bottle jack, so that's probably not a good idea. It has a very small contact area, and it will probably bend the pan.
Phone book is an excellent suggestion!
