Hows your meth setup
MellowVR4
Milwaukee, Wi
ive been thinking on goin with the METH, found a couple ways to install it. I have dsmlink, so can i just hook it up to link or can i just have it come on at after a certain boost setting. Hows your meth setup hooked up, If you dont mind to share, please do. Thanks in advanced.
Well you can check out this thread: click
A similar setup is going on my car. I have a Snow Performance stage 2 kit that is controlled by a progressive controller. It takes a boost signal and ramps pump voltage to make a water/meth injection curve. I'm planning to run it very much like Wop has his setup in the link above, except with the addition of a progressive pump controller. His setup uses a dual tuning map for the meth, and also has redundant checks built in to ensure the car knows the system is actually moving liquid.
LIV4PSI
O-H-I-O
I like progressive controllers. I have a Labonte controller on my STI.
MellowVR4
Milwaukee, Wi
i just found this
MellowVR4
Milwaukee, Wi
Also, do i need some special brand mix of meth? or can i just use windshield washer fluid???
LIV4PSI
O-H-I-O
You can just use washer fluid. A 50/50 mix with water is common. Not all washer fluids are pure methanol so just make sure you buy the right brand
Also, IMO dual nozzles are overkill. I would add a check valve. I also found it cheaper to piece together my kit from Devils Own, buying the controller and tank elsewhere.
MellowVR4
Milwaukee, Wi
Devils own was the kit i was goin with minus the reservoir, ill just use my oem tank.
MellowVR4
Milwaukee, Wi
so just the blue washer fluid would do just fine?
I use pure methanol purchased from the same places you get racegas from. It's cheap enough and I feel a bit more comfortable knowing its something meant to be used as a fuel, not as a window cleaner with other things mixed in.
MellowVR4
Milwaukee, Wi
i need to do some research to see where i can get some around my area.
LIV4PSI
O-H-I-O
Quoting turbowop:
Other things aren't always mixed in. The bottles I use say 100% methanol on them.
Because of European environmental standards, many car companies are switching to ethanol for windshield washer fluid, so be aware.
Quoting LIV4PSI:
Quoting turbowop:
Is the fluid clear? I ask because sometimes the coloring sh*t gets into the pump and other components. For me, the more pure it is, the better. One thing I don't want to have issues with is methanol at WOT when I'm running 30psi and the timing is turned up.
JNR
ca
HEET (not Iso-Heet) is 99% methanol, fwiw. [EDIT - pulled the MSDS from Grainger although if you want to know what is in something, search for its MSDS and go to the source, rather than internet hearsay /ubbthreads/images/graemlins/smile.gif
Some washer fluids have higher amounts of methanol than others (but the highest seems to be in the 30-50% range), but most do not have much (~5-10% if that); a quick clue they don't is if it only states 32 F and up, where as the lower numbers (like -20 F) would have more %, but still has other things...seen various colors and I'm sure there are clear ones out there too (with the higher meth %) if that's a concern, but can't say that is 100% true..high meth % washer fluid is not common here, since we do not get cold weather, but it does exist of course. Be careful with washer fluid though, since many also have glycol (not good for W/M inj.)
MellowVR4
Milwaukee, Wi
yeah thats what i was concerned with the antifreeze additive. my guy knows a place around where i can get the pure stuff by 5gal incraments which should last me a long time.
LIV4PSI
O-H-I-O
My tuner and the owner of Devils Own told me washer fluid was fine. I've been running it for years in my STI with no issues. Just my opinion, but the stuff made for racing can't hurt either. Also my car isn't tuned for it, its just a safe guard since Subaru ringlands crack when you look at them wrong. /ubbthreads/images/graemlins/banghead.gif
EMX5636
Bucks County, PA
I'm running dual nozzles (500cc x2) with an inline shutoff solenoid that is just a more expensive check valve. I run VP M1 methanol mixed 50/50 with distilled water. I've seen and heard of the blue washer fluid building up inside the nozzle and intake manifold. Your call though. A 5gal can of methanol can last me a pretty long time.
I'm using DSMLink to control mine. It won't come on under 20mph (keeps it from spraying while I'm spinning in 1st and 2nd) and turns on about 17-19psi above 3k or so RPM. I can get my actual numbers from Link if you want them. It will also turn off with the clutch switch, which keeps it from spraying while shifting and on the launch. Also lets me run the AUX map as my meth map, and keeps the main maps as my lower boost, straight pump map.
MellowVR4
Milwaukee, Wi
i just dont know how to set it up on link. so i was just gona use the controller that comes with the kit.
ECMlink is by far the best way to do it as well as make more power. The aux maps are awesome for tuning. And being able to control when it turns on with whatever parameter you want is nice. My failsafes are outside of ECMlink, but I do use it for the secondary maps to pull fuel and add timing. And I will be adding new parameters to keep it from spraying when building boost at the line while stutterboxing. Right now it's setup on a Hobbs switch, but that is going to change come spring.
MellowVR4
Milwaukee, Wi
i would love to set it up this way for when i go get it tuned again. I just dont know what wire goes where and what not.
