How hard is it to go 5lug on a vr4?
Illinoisinc
Active member
Chicago, IL
Good morning guys,
Ive been researching on the net about vr4's and noticed a lot of them are 5 lugs. Did they come 5lug? or is it a eclipse swap? if so how hard is it to do that?
Thanks
Jesh
Soldotna, Alaska
No none of the VR4's came with a factory 5 lug, you can swap it from a most dsm's. And from what I've seen and heard its not that difficult, but I personally have not done it, Maybe one of you guys that have could chime in with the particulars.
thomcasey
Indianapolis, IN
I did mine the easy way:
1. Yanked the ABS
2. Installed a 4-bolt complete rear subframe from a 92 TEL
3. Installed complete front knuckles with hubs from a 92 TEL
4. Recirculated rear PS lines
5. Fresh alignment.
Fish
Idaho Falls, ID
It's not too bad of a job. Basically all you are doing is replacing the wheel bearings and putting 5 lug hubs in place of the 4 lug ones.
slugsgomoo
Tacoma, WA
just remember, 5 lug hubs have 20% more rotating weight than 4 lug! /ubbthreads/images/graemlins/wink.gif
Of course, that 20% figure is only valid if you are counting only the weight of the studs as your rotating weight. /ubbthreads/images/graemlins/wink.gif
Quoting iceman69510:
Don't forget the nut....
Rrriiiight. But we're all nuts here.
