Head Removal Question
kumfasa
Tauranga, New Zealand
Hi All,
Timing belt went on me a few days ago and I'm taking the head off to assess the damage. Tragic story read my other post if you want some background.
Have never done it before but am a capable and practical kind of guy.
I have it to the point where I'm almost ready to remove the head bolts and lift it out.
My question is about the exhaust manifold.
If I unbolt the manifold to turbo bolts will the head just lift off?
The angle of the manifold to turbo stud look off from the angle of lifting the head straight up.
Cheers from the land of the long white cloud.
fuel
Toronto, ON, Canada
does the engine block have studs or still standard head bolts? If head bolts still, then you just remove them one by one as you undo them and lift the head off from the locating dowels (about 5mm high) - the turbo will have enough flex on the water/oil lines and exhaust that you can then tilt the head once you're off the dowels. If you have studs in the block.. well then you're better off removing the exhaust manifold and turbo first.
kumfasa
Thanks Phil,
Its good having someone in a different time zone. I get replies even late at night. Ill post some pics in the other thread once I get the head off.
fuel
Toronto, ON, Canada
yeah it's not for another few hours until the Americans wake up! Must be getting cold there now? I'm coming back in a couple months.. not really looking forward to leaving European summer for a New Zealand winter /ubbthreads/images/graemlins/uhh.gif
NZ winter can't be that cold. Besides, does England even get summer? /ubbthreads/images/graemlins/wink.gif
fuel
Toronto, ON, Canada
it started snowing in the south in April, and where I'm from it is around -5C (20F) which is colder than it gets here in London that's for sure. I haven't really stuck around in London/England for a full summer so I can't really comment but London averages 25-30C (77-86F) with the highest recorded being 38C (100F) just a few years ago.
OK, I'll give you that 20F is winter. That is a semi-mild winter day where I am from.
kumfasa
Quoting fuel:
Winter is definitely here, cold unless your out of the wind and in the sun, and those spots are hard to find when its raining /ubbthreads/images/graemlins/wink.gif
I chased the winters around the world for a while and even though the snow was great my first summer in 5 years was so so sweet.
