has anyone used tactrix 2.0
Andy_S
Shithole Wisconsin
Thats a flash cable for obd2 mitsu cars. Doesn't work with a vr4 unless you graft in an evo ecu. I believe there is info on that in the tech section.
coolclean577
Omaha NE
Its for my buddy 99 gsx. It really don't say what it does beside flash . So you know what it does, is it better the ecmlink or data logger?
Brunoboy
San Bruno,CA Home of SFO
I rather use ecmlink, I find it easier to use because it's less confusing. I used to use a tactrix cable to tune my brothers Wrx up until he switched it for a Cobb accessport.
ktmrider
Tempe, AZ
Tactrix 2.0 is for CANBus cars ( can be used on older OBD2 systems tho ). T1.4 or older rev works on most/all non-CANBus and is way less expensive plus still has the data storage capability.
Get T2.0 if you want the flexibility for many newer cars, T1.4 if you want storage, T1.0 for everything else.
I even used a VAG-Com cable on my 05 LGT Scoobie, bought it for $20 online and had free OSE tuning software. Instant ECU access.
coolclean577
Omaha NE
How you guys tune it bec it don't got no imfo on hooking it up or tuning it. What does it do? Or how does it work.
moduleunknown
Elk Grove, CA
I use ECUFlash w/my 1.3 cable (not for my vr4 of course). Look it up, it's free.
As for logging, there's mitsulogger (also free) or evoscan.
See if you can find a ROM for a '99 2G, load it up in ECU Flash and poke around to get an idea of what it's capable of.
moduleunknown
Elk Grove, CA
There's also tons of info on evolutionm.net in regards to ECUFlash. Of course it's all related to the evo ECU, but again, it should give you a good idea of what you might be able to do, or even make you want to try and stuff an evo ECU in the 2g. /ubbthreads/images/graemlins/smile.gif
ktmrider
Tempe, AZ
Quoting CoolClean577:
All it does is connect an external monitor ( laptop, notebook, smartphone with App, etc ) to the OBD2 ECU, nothing more or less.
You would need specific tuning software for the vehicle ECU, it will not come when purchasing the Tactrix brand cable.
coolclean577
Omaha NE
Bec he running 550s And and s16g about 15psi stock intercooler piping got a 1g intercooler and a garrett bov. Don't know what in the motor he just pick it up for a grand. 88k ill take a look at the web site. Thanks for the info
Scientist
Roseau/Dominica
Quoting ktmrider:
2.0 Cables are not only for canbus...they are also the only cables that work with the H8 ecus found in the late 2Gs, Evo 5-6, 8G VR4s and late 3000GTs. Look up ceddy mods in the evo ecu section of DSM tuners. he has great mods of the ecus including Speed Density
