Good Clutch for high HP 600+
jeverts
Hartford, WI
For the bigger HP guys. What are you using for a clutch? I am planning on being over 600hp to the wheels.
89Patches
Ontario Canada
Triple disk or one of dem south bend clutch's. I have one in my car and really like it. I have no clue what "stage", They have way too many. /ubbthreads/images/graemlins/rofl.gif
transparentdsm
Cherry Hill, NJ
i second the south bend. call them and have a conversation about your goals and what the car is goingto be used for and they can point you the right way. i called a few months back about one for when i put in my TRE stage 2 trans and they were super helpful. i called them based off what Mark(turbowop) has said about them and when i asked him he said talking to them to best suit your full needs and he couldn't have been more right.
EMX5636
Bucks County, PA
I run an Exedy Twin. If I were going to do it again, I would just by the Magnus triple. It's tits.
Street Surgeon
Omaha, Nebraska
Tilton carbon/carbon /ubbthreads/images/graemlins/smile.gif
best is an auto swap.
MellowVR4
Milwaukee, Wi
Idk man, the dsm auto trans are pretty strong and shift great IMO. /ubbthreads/images/graemlins/dunno.gif
thomcasey
Indianapolis, IN
I would love to go auto with a slap shift in my galant. Even for a daily.
Quoting 89Patches:
Tell that to your brother, Canada.
Quoting 89Patches:
Did some roll on's with my brother. His evo vs my galant. I cracked the ringlands on 1&2, 30psi compression. He also stripped 4th during the same pull. /ubbthreads/images/graemlins/rofl.gif
jeverts
Hartford, WI
I talked to Tim @ tmzperformace he got me all squared away and a good set up for the car. Comp flywheel with a southbend full ceramic disc he told me would be the best setup for what I want to do with the car and the hp that I am going to be pushing.
I have had 2 trans rebuilt by him and now I am probably going to be getting a clutch through him. If anyone is looking for that stuff I would highly suggest you go through him does amazing work on transmission for a good price and is very knowledgeable.
No, but your eluding to the idea that an auto sucks up all the power and you go slow. Which is not entirely true.
Autos are just as fast as a manual. Less fun for road racing and auto-x, but a great alternative to anyone looking to go straight, go fast, and do it reliably. An auto set-up can coat the same as a 2-3 disc clutch in some cases, far less than a 1k clutch set-up and 3k manual trans to take the beating.
I was just giving Canada a hard time. I know he's aware of the perks of an auto trans. He was just being a smart ass, which I'm always fine with.
Most guys these days turning low numbers in the 1/4 are on auto boxes. They are cheap, reliable, and can take a ton of abuse with little modification. I don't think you can really dispute they aren't optimal for a drag car running sub 10 second passes.
SB seems to be a popular choice with high HP builds. I think their good customer support helps sway people toward using their setups as well. I've always heard mixed opinions on twin disc setups of various flavors. I think that perception usually varies depending on what the user expects from a twin disc, and then what the user actually gets.
89Patches
Ontario Canada
You know, I actually really don't care what trans is used. I thought the pic was funny so I posted it. /ubbthreads/images/graemlins/rofl.gif
jeverts
Hartford, WI
Tim said this will work just fine. I would like to comfortably drive the car and race it here and there but 90% of the time I just want to enjoy the car and drive it. I had a PTT twin disc in it before and it was a whore to drive around.
diambo4life
Edmond, Oklahoma
I made 700whp+ on an ACT 2600 with a Clutch Net 4 puck disc. Granted it was slipping at that point with 500+ wheel torx. /ubbthreads/images/graemlins/bawling.gif. /ubbthreads/images/graemlins/laugh.gif I now have a 3200PP with the same disc and with the power turned up, it holds solid. YMMV. /ubbthreads/images/graemlins/dunno.gif
I always liked ACT. Nothing fancy, just a heavy ass pressure plate with your choice of disk. I've been through my fair share of ACT clutch setups, and have never been disappointed. Sure, there's nicer stuff out there, but for the price ACT is hard to beat.
