Galant eating ECU's
gvr4ever
central Indiana
Check the door seals and the sun roof. If the sunroof leaks, it has 4 outlets to keep water from getting in the car, but they can run down that side of the door.
mitsu90
Illinois
I have only had a wet floor on the drivers side. The passengers side has never been wet.
mitsu90
Illinois
Thats seems to be the case /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/bawling.gif
fivestardsm
Middle, Michigan
Granted, I agree with the repair or replacement of the harness, but I Just want to trow this out there, I burnt 2 ecu's in a row because of a bad/shorted CAS. It only took a couple days for the second to go.
stevep
St. Charles, IL USA
Quoting mitsu90:
and like I said the middle ecu plug it covered in green gunk.
Quoting mitsu90:
It has been awhile. But I am still having this problem. I burnt ECU #4. It is the same as the others same green crud and same cap burnt. I will get pix of everything in the daytime..I only have one ECU left and it's my good eprom, I need to solve this problem once and for all.
If it's the same damage, you may need to take the connector apart and clean all the pins and then find the leak.
I just had to replace the edge connector on a GVR4 ECU the the same sort of problem.
